Brian Keeler
OK, I hooked up 55W Halogen's with the factory fog light wiring and now what to keep lights on when in high beam for off road use. Should I wire seperately to avoid overloading the circuit? Or is there an easy way to disable the feature that cuts power to fog lights when hi beam turned on without causing an over load on the circuit?
Sorry if this has been covered but I did search for a couple hours on here and could not find the specific answer...:redbrick:
Thanks for any help!
