How do I get into 4WD?
Status
Not open for further replies.
I don't believe the lever on the Gen 5 transfer cases actually go to the transfer case - they are electronically actuated.
Mostly there for looks
Could be, but not sure I agree. There's an engine/tranny-based vibration in the lever, and you can distinctly feel it change when you go into 4H and/or 4L. And I'm not sure why Toyota would bother doing something that probably would cost even more money (a series of levers and dash panels) when a button would be cheaper.
Reminds me of the story (perhaps apocryphal) about novice computer users who, when confronted with an instruction to "Press any key to continue," called up tech support to say "I've looked everywhere, but I can't find an 'any' key anywhere on this thing!"
It is a lever that has a connection to the TC, but it is still all actuated to the front. It still feels better than turning a knob.
I've had a pretty good variety of 4X4 vehicles over the past 40 years (six I think). I did lots of readying before they had the internet. I can remember a time when I had no idea what a "Hi-Lift" jack was and had to ask.
Since then, I have run into numerous folks just getting into 4X4s and have had to answer most of the same questions I have asked over the years.
The manual for the current T4R confused the heck out of me. What works in 4H vs 4L? Which modes of Multi-Terrain work with which modes of Crawl Control. When does the Rear Locker actually lock? When does A-TRAc work and what does it actually do? What WON'T work in all of those modes?
Even had to make my own spreadsheet to sort it out and keep it in the glove box.
Not to mention several of the 4X4s I purchased used or at auction that did not come with an owner's manual.
I don't mind the more "basic" questions.
The lever directly engages the 4H and 4L gears in the transfer case, but engagement of the electronic actuator on the front axle is still necessary for 4 wheel drive to actually reach the wheels. The actuator engages automatically when 4H or 4L are selected.
My base 2017 SR5 has 4WD (I think) but do I get a visual to know it is engaged? On my display I can see that there is traction on the front axel. Would this image change to two axels?
Also if I do not have 4WD can a shop convert it to 4WD or am I stuck? Thanks.
This can’t be a real post.
You are correct but it does not make it right. Basic questions should be entertained appropriately just as complex ones. And when agreeing to join this forum there are conduct rules. For example, there are a number of people that may ask how various "basic" questions to any mechanic but is the proper response to "read the manual" or does the mechanic use better communication skills to create a healthy dialog?
I’m betting that you were bored and decided to start a thread that would elicit a lot of comments. If your post is indeed legit, you are probably one of those people that should not own an automobile. Public transportation and Uber are your friend.
This thread should be titled “A$$hole Roundup”.
Got some real winners. Just read the thread if you wish but no need to be dickheads, it’s not even noon.
Guys, it is a legit question. If you don't want to help out just move on. There is no reason to act like jerks. Keep the thread on topic. First/last warning.
What I do is pop it in 4lo, then start pushing buttons and hope for the best. Fortunately 4Lo and the rear locker are generally enough and ATRAC is pretty easy. I have the worst time with the Multi-Terrain control... Different modes have different requirements.
I would love it if Toyota would create a "cheat sheet" built into Entune that detailed both HOW to engage and suggestions for WHEN. It wouldn't be hard. Manually opening it would be fine, but it would be awesome if it popped up if you push a button when something isn't available. The "Function not available" only tells me that the rig knows what I want it to do, which I guess is better than nothing. Sometimes I push a button and literally nothing happens...
Comments such as these inhibits others to post. Why would you and others assume that there was no research done before a post? Encouraging others to be derogatory never should be allowed to pass the moderator's filter. Thanks.
Toyota should not have put both ATRAC and MTS together in the same vehicle. They're just different buttons for essentially the same thing. In the new Tacoma they either put ATRAC in the MT version and MTS and Crawl together in the AT version. No more overlapping confusion. The 2019 rav4 gets MTS.... and from the one video I've seen it appears to actually be the same thing. If it makes it into the highlander - there's potential for a fantastic IFS/IRS overland vehicle that would offer better highway driving and pretty decent capability for most off highway destinations. The fact that MTS is standard on all AWD rav4s, but requires you buy a TRD OR tacoma to get it blows my mind. WTF toyota?
IMO an automatic locking rear diff would not be a good idea. But having an automatic MTS/ATRAC setting that adjusts based on speed would make a lot of sense. I think it would also make a lot of sense to simply have MTS engage when you put it in low range, and the max setting be automatic when you engage the rear locker. Rather than turn it on - you'd have to turn it off.
So, did you read the manual and figure it out or are you still waiting for the forum mechanics to answer lol?
It's easy to tell if it's in 4WD. You'll see on your dash that both axles are iluminated. When out, nothing is illuminated. Hope you weren't daily driving it in 4Hi/Lo. You would know if you heard any binding while cornering.
No, they want to keep it open to hand out "warnings" to the vast majority of the posters in this thread instead of addressing main issue.
Obviously you don't get it. One of the main issues is people acting like children instead of civil and just helping people out. This was a legit question. It is pretty simple, if you have nothing constructive to add just move on. I made it clear it was a first/last warning and now you want to complain about us not doing our job. Enough is a enough
I did test drive a used 4Runner once and the dealer told me it was 4x4. It wasn't. If I wasn't familiar with 4Runner enough to know that it was missing the shift lever I might have been duped. That was the only 4runner I've ever actually seen that was 2wd, so even for someone who knows the difference it wasn't obvious. It also had a 4x4 emblem on the back. Shady dealers do shady things... fake badges are not uncommon. https://jalopnik.com/do-dealerships-put-fake-badges-on-cars-1755147997
Also - another funny story about the same sort of issue. On a construction job once we were using a client's F550 dump truck along with our own dump truck to haul in some landscaping materials. It was a little muddy and I couldn't get the 4x4 to engage. I had no idea what was going on. I moved the lever. No front drive. I looked and there were no locking hubs. Turns out the truck had some aftermarket wheel covers and there were locking hubs inside. I had no idea not being familiar with the truck that it had locking hubs hidden inside the wheel covers. I had just assumed that no one was still selling trucks with manual hubs. Just one of those things that you might not know if you were new to this type of thing.
My main point is simply that I've been there too. Seems silly not to know, but I can see how it happens. Especially if you've never owned a 4x4 before.
Just like people here to trd pro badges on their crap when it isn't. Then they trade to a dealer and the dealer lists it as a trd pro.
The lever does indeed go directly to the transfer case but as was already stated the front axles disconnect is still electronic just like the dial controlled electric actuated transfer case 4runners
Don't insult the lever
OP, you have to admit, the folks who built and designed your vehicle wrote a manual for it. Wouldn't that be the best place of information vs. the internet? Secondly you spent (I assume) tens of thousands of dollars on something that you were not sure of a major mechanical system (4x4) was in place, I mean come on that's asking for internet comments
I don't care what you ask, its the internet, but don't be shocked by responses you get (again its the internet)
Status
charlesz
