How do I get into 4WD?
Status
Not open for further replies.
sunnah
Member
My base 2017 SR5 has 4WD (I think) but do I get a visual to know it is engaged? On my display I can see that there is traction on the front axel. Would this image change to two axels?
Also if I do not have 4WD can a shop convert it to 4WD or am I stuck? Thanks.
Do you have the top right knob? If so, use that to switch to 4wd. I have never seen the interior of a 2wd 4runner so not sure what would be there instead.
Put the truck in H4 when off road or in wet/slippery snowy conditions. To do it you can be driving as long as you are under 50mph. Just push the little button in and twist. Don't drive in 4hi on dry pavement as turning will "bind" the drivetrain. Don't go above ~50mph in 4hi
Put the truck in L4 when going slow and over challenging off road features. To go in L4 you must already have been in H4, then you must come to a complete stop, put the truck in neutral, push the button and I believe down to twist to engage L4. There should be a button up on your headliner near light switches with ATRAC, which will help compliment the 4lo if you are in extremely difficult terrain. This should be slow/crawling speed. Do not go fast in L4.
When you are in H4, you will see this green symbol.
When you are in 4lo. You will see this
Wow! Did you just have these these pics ready. Than you for getting into the details. I do have have the knob and will do as you suggested. I appreciate it a lot. I was starting to think I got suckered into the purchase and was just entertaining various thoughts in my head.
OP wins the prize!
Stupidest question of the year!
Your prize is a slightly used owners manual. Open your glove box to claim your prize. Now you just have to read it...
I did test drive a used 4Runner once and the dealer told me it was 4x4. It wasn't. If I wasn't familiar with 4Runner enough to know that it was missing the shift lever I might have been duped. That was the only 4runner I've ever actually seen that was 2wd, so even for someone who knows the difference it wasn't obvious. It also had a 4x4 emblem on the back. Shady dealers do shady things... fake badges are not uncommon. https://jalopnik.com/do-dealerships-put-fake-badges-on-cars-1755147997
Also - another funny story about the same sort of issue. On a construction job once we were using a client's F550 dump truck along with our own dump truck to haul in some landscaping materials. It was a little muddy and I couldn't get the 4x4 to engage. I had no idea what was going on. I moved the lever. No front drive. I looked and there were no locking hubs. Turns out the truck had some aftermarket wheel covers and there were locking hubs inside. I had no idea not being familiar with the truck that it had locking hubs hidden inside the wheel covers. I had just assumed that no one was still selling trucks with manual hubs. Just one of those things that you might not know if you were new to this type of thing.
My main point is simply that I've been there too. Seems silly not to know, but I can see how it happens. Especially if you've never owned a 4x4 before.
OP wins the prize!
Comments such as these inhibits others to post. Why would you and others assume that there was no research done before a post? Encouraging others to be derogatory never should be allowed to pass the moderator's filter. Thanks.
You're on a forum with many people. You think you're not going to get heckled about a basic question that you could have easily found in said owner's manual or search boxes?
So maybe you can answer the question: what is in the place of the shift knob or shift switch on a 2wd only 4Runner?
Moron. What's even more hilarious is I bet you work in IT for your dayjob, so you damn well know how and where to check online.
Hopefully you did get suckered for buying a 4Runner and not even know what 4WD is or how it works lol.
You are correct but it does not make it right. Basic questions should be entertained appropriately just as complex ones. And when agreeing to join this forum there are conduct rules. For example, there are a number of people that may ask how various "basic" questions to any mechanic but is the proper response to "read the manual" or does the mechanic use better communication skills to create a healthy dialog?
Unfortunately, you won't be able to stop comments such as these, so ignore them. Enjoy your 4Runner and your new discovery of its capabilities. Winter's coming - maybe you'll get to mess round in some deep snow soon. Always fun in my book. Enjoy!
Sunnah please help.
Could you advise me where I place food into my body if I am hungry?
I'm beginning to worry that I might starve, unless I can be advised on this forum what to do with this food on my table. I have a feeling I'm supposed to stick it somewhere inside my person, but not sure. Maybe I do something else with it?
Another cupholder. It was a 3rd gen 4Runner. The limited has a 4wd button on the side of the transmission shift lever - but also a second lever for low range only.
I don't believe the lever on the Gen 5 transfer cases actually go to the transfer case - they are electronically actuated.
Mostly there for looks
Status
Jhunt
