How do i program the remote start on my 98 4-Runner SR5
ArmyGreen9360
I have a 98 Toyota 4-Runner SR-5 and it seems to have a factory installed remote start but it will not work on my key fab. It worked before, then i broke the keyfab and had to get a new one. Everything as far as keyless entry workson the new one but for some reason i cannot get the remote start to work again. I really wanna get it to work. I don't really know if the security and remote start is factory installed. Under the hood, there is a green sticker that says this vehicle is equipped with a remote starting device and to make sure it is disabled before servicing. Anybody know what to do?
Since no one else is chiming in I'd suggest that if it's a factory installed remote start it may be helpful to post up in the 3rd gen forum, I doubt a lot of guys with 4th gens know anything about this.
I didnt think there was a factory installed remote start?
Pretty sure there wasn't. There have been a few that will trigger off of a factory remote through various methods over the years.
Any pics of the sticker, old remote, or new remote?
Have you taken a look under the dash to look for aftermarket wiring? Maybe you can find a black box and get a name and model number if it is aftermarket.
The sticker is green and it doesnt have anything on it saying what it could be. I never thought about looking under the dash. I will post some picture on here tomorrow at what i got. Its kinda wierd cuz the light that flashes for the security, you can push it in and out but it doesnt seem like it does anything. And also there is a very tiny toggle switch by the floor board on the driver side that i cant figure out what its for. I dont have fog lights or anything so i think it may have something to do with the security or the remote start cuz when i first found it, i messed around with it then a couple days later my buddy went out to get something out my car and hit the wrong button and my car started. And after i lost the remote start it didnt work with the new one.
Yea i already tried that. Im thinking maybe the new remote isnt programmed to the remote start. Even when i do flip the switch up. Im gonna get in there tomorrow and start doing some digging. Take some things apart and try to trace where that switch is connected too. And maybe try to find where the remote start chip is located and get a model number or something i can identiy it from.
Definitely not a factory installed option. Is there a box under the drivers seat of your 4runner? What does the remote look like? I think you may need to pull the lower part of the dash under the steering column and look for aftermarket alarm boxes to see what you have.
When you flipped the switch and tried to start the 4Runner, it started...? I was going to bet it was a kill switch.
I'll guess alarm valet switch. If the ignition is on and you flip it does the red light on the alarm go solid red? Or it could just be the a kill for the auto start to put the vehicle in service mode.
well i have the same sticker on the inside of my firewall on the d/s....and i have a switch on my d/s kick panel but all i have is the old "L SHAPED" 98 door lock transmitter but when i hit the green button my headlamps turn on then turn off after a few second....wonder if we both have the same issues....should be interesting to see if we can get these bad boys working and if they are factory...ill ask my old co-workers at toyota and see if it is or isnt factory.
I totally found the solution to this problem. Got my remote start working. And i am gonna post how i did it very soon. Let me put something together, and its amazing how many people out there are having this same problem.
Hopefully the solution to this remote start issue
:boxer: So to start from the beggining, i spent like 4.5 hours today figuring out this problem. I have a 98 Toyota 4-Runner SR5. My vehicle came equipt with an after market security and remote start system. My keyfob for the system is a "Kindney" shaped transmitter with 3 buttons on it. A big red button on top, a small black button underneath, and on the bottom a small green button. There is also a small red LED push button(This is your reset button you will need to press in order to get into program mode) on the left side of the steering wheel next to the light control wheel. There is also a small toggle switch, which is called a vallet switch, located underneath the dashboard on the driverside kick plate. When the vallet switch is on, then the remote start does not work.
Now the problem was that i didnt know i even had a remote start until about a 9 months after i bought my SUV. I knew the green button had to do something, and i wasnt sure what it was untill i noticed a neon green sticker under the hood on the driverside firewall that said "This vehicle is equiped with a remote engine starter......Blah blah blah" The remote start would never work though. To make a long story short, i found that my vallet switch was turned on the whole time so my remote starter would not work. So when i turned the vallet switch off and hit the green button a few times i heard my car make 2 ticking sounds which i believe is the headlights flashing, then my car engine started. Your remote transmitter would have to be programmed to the remote starter and most important of all, you have to have a remote start in your car. I actually searched for it and found it finally. Im not to sure if everybody with this set-up will have the same system that i have. My remote and system is actually made by audiovox.
When i lost my keyfob, i had to get another from the Toyota dealership. It was the same "kidney" shaped transmitter i had before and had the letters TDS on it. The people at the Toyota dealership got the lock and unlock buttons to work, but i guess they never got the remote start to work. So i pretty much research all day today and found out how to program the remote start to the new transmitter. What i recommend is to not waste the time and call audiovox tech support.
Audiovox technical support- 1 (800) 876-5581
Just listen to the options and once you get to a tech support operator, explain to them what you problem is and they will walk you through the reprogram process. The reprogramming was very simple and it works like a charm now.
I hope this helps and if you have anymore question about any details you would like me to ellaborate on just let me know.
OMG iM dying right now!!! PLEASE UPDATE US!!:jump:
No Remote
I just got a 98 T4R SR5 given to me and am going to try to make improvements to it as time goes along. It came with 3 keys and 3 "fobs" (one red and 2 black) for the installed immobilizer. But it has no remote at all. It has power door locks and under the hood is the decal as described earlier in this thread (see pics). I've never owned a Toyota before so if some of my questions sound "newbieish", I apologize. Does the presence of power locks mean I should have "keyless entry" capability? How can I tell if the "command start" is still installed? Where would I get a remote control to control the power locks and/or command start? The T4R has 191K km (115K miles) on it and I only drive about 6K miles/year so I'm hoping this baby lasts for many years yet.
Thanks for looking.
MaximussK
