How Do You Change a Tire (Jack Recommendations)?
Munson
Hi All,
Looking for recommendations on how ya'll with lifted rigs change a tire either on the side of the road or a trail (not at home). I have about a 2.5" lift using Icon Stage 2. I have a hi-lift jack but stock bumpers. I dont trust my N-Fab bolt-on "sliders" as a jack point for the hi-lift unless someone has information to the contrary.
I'm thinking the best option for me is to get a floor jack but I have no room to keep it inside the truck and secured. I was thinking about putting it in a case on my roof rack but that would not only raise the center of my gravity but also be heavy lifting up and down.
What is ya'lls plan if you get a flat while out?
Thanks,
M
Have you tried the stock jack? I have a 3" lift and I can get any wheel off the ground with the stock jack with room to spare. Rear wheels are easy since you are lifting the axle, but the front is a frame lift behind the front wheel. I should also note I'm on stock sized tires.
I have not done that offroad yet, but I have a hi-lift base plate that'll stabilize and lift the base of the jack a little bit.
There is also safe jacks: Safe Jack - 4WD, Outdoor,Off road, 4X4 accessories and products.
and I found a guy that makes top adapter for the stock toyota jacks here:Jack Adapters - Land Cruiser Products - LCP
I've asked on the safe jack website if their adapters will fit over the toyota bottle jack and haven't ever heard back, but based on measurements, it wont work. Which is a bummer, I'd like to get their extension set, but not sure I want a hydraulic bottle jack to use it.
You got me! I haven't tried the stock jack yet...but I did use it when the truck was stock and I wasn't really a fan.
However....that safe jack looks awesome, I think that will work great for what I am looking for! I really appreciate it!
M
Stock jack works fine under the rear axle or under the lca in the front on a flat surface. You just have to load the suspension enough to get the tire off and back on. You don't need a lot of clearance if you're just changing a tire.
You also don't want a jack that is too tall to get under a jack point when the tire is flat.
Stock jack + 6 ton bottle jack + 2"x6"x12" + 4"x6"x12" has sufficed for more situations than I've encountered
Sent from my SM-G955U using Tapatalk
thadjay
