How do you take off waterspots?
MikesToy
Banned
Just like the subject says. I got waterspots on all of my windows. You can't really see them unless you're close. But they bug the hell outta me.
:cannon: Waterspots
Just buy a polish for that exact problem. Check out Zainos, they have a glass polish that I have heard works wonders.
Yep, there are lot of polishing brand out there. Try the simplest one, and after cleaning your car with water and soap. Wax it or wipe it with clean cloth to eliminite these spots.
__________________________
Autopartswarehouse is a must!
My new SE came from the dealer with way too many spots, so super thick. I actually started with a razor blade first. Then super fine steel wool. #00. Even claybar. I have removed about 90% of it. the steel wool did the best, good luck.
qballjr13 said:
Distilled white vinegar will take care of the problem. Maybe try this before the steel wool.
I too read about the Distilled White Vinegar to remove water spots on the glass.
It was even in the Owner's Manual in my old Honda Accord.
I tried it last night...did not work!!
Dilute it (1) part Vinegar (2) parts water...did not work.
100% Vinegar...also did not work.
Sorry I didn't mention white vinegar was a waste of time. That is when I felt the spots and tried a razor blade. That knocked down the big spots, then steel wool. then clay bar. I can live with it now.
Wow, you guys must have some insanely hard water in your area! :)
I'm thinking of getting a water de-ionizing system to avoid water spots in the first place. More importantly, cause I'm lazy, so doing less is more. :D
Similar to the Mr. Clean auto dry, except it'll last much longer.
Maybe a solution
I have the same problem. After doing significant research, I am going to purchase autoglym glass polish tom. Ill let u know how it works.
Re: Maybe a solution
Thanks! I still have waterspots (i guess from the rain) on my windows.
I've responded to a similar post before so I figure I should repeat it here. Forget any special cleaners or concoctions, use steel wool. I use 0000 steel wool but you can use 000 and up to 00 safely on glass. It works perfectly, the steel wool lasts a long time, and all you have to do is follow it up with a regular glass cleaner. Just be careful around the edges near rubber trim.
Whatever method you use to remove the spots, apply a wax or better yet a sealant to the glass afterwards to keep them from coming back or at least it makes it easier to remove if they come back.
My friend sells car detailing supplies and he likes to use wheel acid to remove water spots. Just make sure to rinse well after, works great though. Not sure about really bad spots.
Maxil
Don't use steel wool on the back window of a 4th Gen. It will scratch it.
Megs 105 with a polisher, followed by 205 will clean it up nicely and get rid of the water spots. It will also take outs smaller scratches and dings in the glass.
1) Clay first (safe on all glass, including the coated windshield/ front doors/ hatch glass on the 4th gen)
2) Steel wool #0000 works well, with your glass cleaner of choice as a sort of lubricant (Windex is fine for this). DO NOT use steel wool on the coated glass!
Steel wool takes some time and scrubbing effort. #0000 is very fine grade and doesn't have a lot of cutting ability, but that's also what makes it pretty safe.
HAHA! Your all wrong!
I had hard water spots too and ive spent the last year trying different things. The only thing that ended up working was a solution called "bio-clean water stain remover". I picked it up at a local commercial solution store for $15. Took it home and got to work.
here is a before pic, and it really doesnt do it justice for how bad it was:
DSCN3609.jpg~original
i did the drivers window in about 10 minutes but dont get me wrong, its alot of work.
Dont be mistaken, the first picture is of my window, what your seeing is the reflection:
DSCN3610.jpg~original
same with the 2nd:
DSCN3611.jpg~original
You can also find this product online. Search around though some are priced at $21 and others at $13 so price shop because they are all the same product.
I have nothing to do with this product other than being a satisfied customer, but I personally guarantee it to work 110%
p102bioclean.jpg~original
Not sure what type of steel wool you have used, but I just detailed an '06 SR5 and used 0000 steel wool on every exterior glass surface including the side mirrors. No scratches and no water spots. If you can scratch automotive glass by hand with 0000 steel wool then you need to lay off the steroids
thadjay
