How far can you go on empty?
Glad to know I'm not the only one with this deal. Just posted about it in the "fuel gauge" thread...
My '96 falls on Empty yet only takes 14-15 gallons per fill up. At least there's a safety margin built in...I guess!
I've gone as far as 40 miles after my light's come on before filling up. Like everyone else, if I fill up right when the light comes on, it usually accepts about 15 gallons.
This all makes sense: 18.5 gallon tank - 15 gallon fill up = 3.5 gallons left when the light comes on. I get about 18 mpg, so I could probably drive up to 60 miles after the light came on before I'd run out.
BTW, I seem to get better mileage if I fill up around half a tank vs. when I fill up when it's nearly empty. Or maybe it's all in my head.
I felt i was really running mine down last week and actually thougth I was going to run out of gas and when I filled it up it just barely hit 16 so I was at least fine for another 10 miles or so but that's cutting it close. My average fillup is usually about 14.8-15.2 gallons.
3rdGENrunner said:
you have to realize that one of the larger recalls related to the 3rd Gen was the fuel gauge/sending unit. Have you ever noticed going to sleep with half a tank and waking up with 3/4 or 1/4 of a tank in the morning? Granted this doesn't effect all 4Runners of this time, but a lot of them.:confused: Go figure. Mine does it all the time, but somehow when I'm low it reads correctly, same when it's full, just not inbetween. :beer: <-- it's kinda like that
Youre exactly right, my 99 SR5 with man trans does the same thing, at first its annoying but i got used to it, i just fill up when it reads 1/4 left on the gauge regardless if its the right reading.
00FourBanger said:
Anyone have any experience as far how much gas is left after the empty line on the fuel gauge?
I know the gauges are different in different years, but when my light goes on in my 2001 it usually takes 16.6 gallons. Since I have a 18.5 gallon tank I figure I could go another 30 miles. I have pushed it another 20 miles and when I filled up, it was 17.8 gallons. The gauge was below the E. I figured it was really low then.
Bottom line, when the light goes on I figure I have a good 15 miles on the safe side.
EnjoyDaRideTRD said:
Run it dry, but have a small tank with gas just in case.
good way to burn up a fuel pump
Jesse1
