How hard would it be to install a low profile front bumper and winch
Ctrulock
If you're not super good with mechanics how hard would it be to order a front bumper and winch and install it myself? I can do stuff like change differential oil and trans case oil, brake pads, radiator flush, etc. I don't know how to fix a broken engine though so mostly suspension type stuff. I think a cv axle would be out of my reach though. Just wondering because I don't want to pay the labor on bumper, winch install lol.
its pretty easy with 2 people when trying to bolt the bumper and winch in place.
Its pretty hard to do it by yourself. You will need a floor jack, and wood to get the bumper aligned because its heavy and awkward.
The cutting part is easy and self explanatory. Just measure twice and cut once.
You will also have to bend a bunch of stuff out of the way very carefully.
I have done multiple installs, and i probably wouldn't ever do it by myself again....lol.
Be careful with wiring though. Route it properly, protect where needed and make sure all connections are very secure. That heavy gauge wire getting cut or coming loose and shorting out can easily end in a 4runner bonfire.
The bumper itself as previously mentioned is easy, it's just physical heavy labor and some cutting.
Unless you want it for looks, consider something like a BudBuilt Hidden Winch Mount. Cheaper. One man installation. Much less weight.
That budbuilt sounds perfect for what I want. Low weight and just a winch for umm... troubles. So you think it would fit a 2022 trd off road 4runner then? Like a standard 9k winch such as rough country, smittybilt, or badlands would fit?
Budbuilts website says 2010-13 models and 2013-22 limited models. Specs on each say doesn’t fit past 2013 and only limited models respectively. Curious if folks have adapted or if it works.
I just bought the LFD winch tray. I like the design. I also plan on buying the artec frame reinforcement pieces as well.
Are the bumpers you guys mentioned working bumpers? Meaning can you use it to haul someone out or get pulled out if needed? Seen one on youtube recently and it had a lot of flex like it wasn't meant for pulling you out. Anyone?
I'm up in St. Augustine and I'll have my Artec Venture bumper up for sale in probably 3-4 weeks. I have a full C4 Overland replacement bumper I need to get painted and installed but am busy the next several weekends.
Winch/fairlead not included but the 30" 5Watt Combo beam Black Oak light bar will be. There's a couple of rock scratches on the bottom of the bumper but you can't see them unless you are on the ground looking up. $650 with the light bar, $750 and I'll help you install it. Cash / local only.
If you're interested PM my your cell# and I can text you some more pics, etc.
Toyota 4Runner 5G Venture Series Bumper– Artec Industries
New - 30 Inch Single Row: Black Oak LED Pro Series 2.0 LED Light Bar - Combo, Flood, or Spot Optics (90w/150w) - Black Oak LED
IMG_0073 by EricT4R, on Flickr
Going with a lo pro bumper isn't just all about looks as they also usually include recovery points.
If you go with the hidden winch mount, you'll also need to buy recovery points since T4R's don't have rated points from the factory.
Install will probably be only slightly easier or the same, and would look cleaner with the hidden mount. But you'll be getting close to the cost of a lo-pro bumper with both of those
After looking at both hidden mounts, the SDHQ says it has recovery points integrated, but the budbuilt does not. But it's a good bit more $
I know what you are talking about. they are meant to be used for recovery, but I would choose one with the recovery points in line with the frame (down low by the winch fairlead). when the recovery points are up high next to the light bar, they act like a lever and the bumper can get pulled down or away from where it normally sits.
The bolded has been discussed to death so not going into it again other than to say it's not true.
Hardest part for me is pulling the trigger on the expense... Don't know how many times i put on in a shopping cart, just to close out the window. In my case it's more of a want, not necessarily a need.
