In the market for a 4runner. Kind of want side air bags, which means a somewhat newer one (2007 or later, I think). But assuming good maintenance, what can one expect out of the eng/trans?
Side curtian airbags became standard on 4Runners 2008 and later. I guess it was an option prior to that.
I would say 200K+ is very easy and 300K+ is very probable with proper maintenance and care.
Correct, side airbags were an option on 2007, regardless of the trim.
Engine and transmission - for sure. The rest of components may not live for so long.
Do you dive?
150k easily, 200k probably. My family had an Acura legend for almost 18 years. 160k miles and it ran like new; however, it was falling apart. It seems the mechanical components of high quality Japanese cars outlast the bodywork and all issues that come with age - rust, corrosion etc etc. Rubber goes, seals leak etc.
Depends on PM mostly.
People seem to dump these things at 90k b/c of an expensive service (v8 at least) They think because its a Toyota is reliable which means, no service. However, its quite the opposite, with good service brings reliability to any car - especially Toyotas.
My .02
Used to. Best dive trip: Gallapagos.
Then I guess it would not matter to you that it easily holds 3 sets of gear with 6 tanks...![]()
I would stay away from trucks with rear air suspension and/or XREAS, as repairs on these components are expensive. And if you plan to keep the truck for a long time, then the question is not IF they'll fail, but WHEN...
Do you dive?
