How much play should an Auto Shifter have?
HappyHooligan
I've noticed that my Auto shifter handle has a bit of play in it when I brake or accelerate. Is that normal?
When I say play, I mean it moves forward a bit or back depending on what the motor is doing.
No, its should not have play. Most likely the shifter bushings at the base are shot and it's moving around. Mine does not budge at all.
I could also be worn/broken transmission or engine mounts.
Shifter bushings would give you a 'loose' feeling both forward and back and side to side.
-Charlie
