[How To] DIY Fender Extensions and Mudflaps (with pics)
bener
Thought I'd share a quick rundown of how I installed fender extensions and mudflaps to stop everything flying all over the place with my running boards removed... Mostly sand - it flew everywhere without these additions.
Used rubber extensions from my local rubber shop - these are specifically made for fender extensions, you can get larger ones but they were very expensive. The flaps are just sheet rubber cut to size - I'm going to add stainless strips on the base of each at some stage.
These just pop rivet onto the inner fenders.
I used small angle brackets for the rear mudflaps - in the front everything just pop riveted on easily, but in the rear I had to use brackets to attach to the small factory mudflaps. Mostly used aluminium and stainless, but these steel brackets were all I could find...
The secret weapon - sticks the fender extensions in place so the drilling/riveting is a one man job. Just used tiny drops.
Cleaned everything up with this before attaching. Used aluminium pop rivets.
Some fine New Zealand beer of course, and a trusy assistant...
The fender extensions were super easy - cut them a bit long, line up one end nicely, glue in place, then drill and rivet. After that I trimmed them up to look tidy.
I just used a rivet for spacing, I'm painting them black anyway.
The front mudflaps were aligned and riveted in place easily too - there were plenty of flat places to drill into. No cutting, just used the pieces I had precut. I glued the flaps to the extensions to create a seamless flow - I made sure the flaps stuck out to the same width as the extensions.
The rear flaps had to come up much higher to meet up with the fender extensions, and I needed to use brackets to attach them to the existing flaps. These were riveted in place.
Test fitting the flaps - the two stainless bolts with the washers are fitted into existing bolt holes - I removed the factory bolts and replaced them. Very useful for lining things up - I just marked the holes in the rubber, punched them with a slightly larger hole punch, and adjusted then tightened to hold in place. The protruding lower bolts are drilled through the bottom of the existing small mudflaps. I trimmed the inside corners to suit once they were bolted and riveted.
From the rear:
I used nuts/washers to space out the gap between the existing mudflap and the new rubber flaps:
Top of rear flap riveted to the first bracket, holes drilled for next brackets:
Completed - two views from rear:
Side:
Went on a surf mission and they worked brilliantly:
Cleaning the salt off afterwards:
All told I spent around $100NZD and 3-4 hours. Well worth the time, hope this is helpful to someone! I previously had sand or mud all over the surf(4runner) every time I went offroad, now it is very well confined.
Feel free to ask me any questions if you have em!
What a beautiful left! Got any equal rights down in those parts?!
Yeah mate! New Zealand has some excellent uncrowded surf!
Here's a few more pics of that break - it's a left that wraps around many points, the further around you go the bigger it gets - it's one of the longest waves in the country, about 2 hrs from home. East coast is cleaner but less swell, west coast is a bit wilder but has much more power/size. I live in Northland, which is the upper north island.: Imgur Album
East coast break on a pretty outstanding day (30 mins from town):
A west coast break 35-40mins from home:
Plenty of surf of all different levels here!
That's what I need! I'm a big fan of nice clean shoulder-high to head high waves. Nothing too fast. Don't hate me, but been getting into the SUP game lately. With the infrequent access to surf around here, I'm all about wave count.
Not another SUP'er :frusty: Just kidding, we're on opposite coasts so I guess you're okay haha
Clocktower07
