How-To-Guide (Grillcraft Upper/Lower Grill)
TOYSTRY
How-To-Installation-Guide (Grillcraft Upper/Lower Grill)
Ok, so I'm attempting to make a how-to installation guide for the Grillcraft Upper and Lower grill since "Grillcraft" did a really crappy job with theirs. What I have below isn't perfect (I missed a few minor steps), but if you use this in conjunction with Grillcrafts directions in the box or online Upper Grill Instructions or Lower Grill Instructions you can't go wrong. Some pics borrowed from Grillcraft because I forgot to take them while doing this today.
Step 1:
Take a before picture you start, because this is the last time you will ever see the old grill on your 4Runner.
NOTE: This modification is irreversible, you will cut up your old grill to insert the new grill. Again, this modification is irreversible!!!
Step 2:
Start by removing all the pop-down pins. Simply use a screwdriver to push down the center of them. Once you've pushed the center down, they pull right out as one piece. Now remove the plastic cover and set aside.
Step 3:
Once you've removed the plastic cover you will see a different style of black plastic pins. Simply use your fingernail to pull upwards and the pins will pull straight out.
Step 4:
Using a 10mm socket, remove the bolt attaching the grill to the radiator bracket.
Step 5:
Remove the 4 screws from the grill, you will only reuse the top two when you reinstall it.
Step 6:
This is the HARD part that everyone is having with removing the grill. Note the green and red circles in the images below. You MUST start with either the left or the right side GREEN circles. Using your STRONG THUMBS, lift on the tabs (they are the color painted tabs vice black tabs) and pull towards the front of the vehicle. Once you break the GREEN circle area tabs loose, you will then do the same thing for the RED circles. Lift and pull forward until you get all the way to the other side of the vehicle and you'll have one last GREEN circle area to tackle.
Step 7:
Cut the interior portion of the grill only. DO NOT CUT THE BOTTOM LIPS OFF OF THE GRILL. Trim the interior, then smooth out the nubs as pictured. You'll need to drill two holes on the top part to mount the grill onto the factory grill trim. I forgot to take a picture of the installation of the grill to the trim but it's self explanatory.
Step 8:
Using a 10mm socket, remove the bolt from the top of the lower grill. Next, using sheer brut force and muscle, you'll need to lift up and pull forward/backwards to break the tabs free from the lower grill. It's a PITA.....just have patience.
Step 9:
Trim the INNER grill portion only. Do not trim the sections where the tabs holes are because you are going to need to reinstall using those same dreaded tabs.
Step 10:
You'll need to drill/cut out 3 slots for the grillcraft grill to sit flush on your Toyota trim piece. It makes sense once you see it. Just follow the directions and use this as reference.
Step 11:
Reinstall the lower grill from the backside of the bumper and pull it forward into the tabs. It's a PITA to align the grill and tabs, takes a try or two, but once you get it aligned, it snaps in easily. Reinstall 10mm bolt. NOTE: Before you install either grills, determine if you want to spray paint the radiator/accessories because uninstalling and reinstalling sucks.
Step 12:
Finally, reverse everything you did to reinstall the grills.
Pics attached. All the original pics I made for these were deleted by accident when I was modifying the privacy setting on photobucket so I apologize for that. All the steps above are still accurate however I don't have pics annotated in order like the post used to have. Sorry :(
:bravo:
A job well done on this write up! I'm sure this will definitely help the others who purchased during the group buy! Looking at all the other Grillcraft runners, I am kicking myself for not jumping on the group buy when I had the chance...
Again, awesome job.
Wow although I've already done this, thanks for putting in the time to do a detailed write up, I'm sure there will be plenty of people that appreciate this! Job well done! Use a double stick tape and a couple of cotter pins to hold your badge on and get rid of the zip ties if you havent already. =)
WOW!!! I'm almost ready to install mine.... need to take the lap top out to the garage. thank you toystry.:thumb3:
For the bottom it was actually easy. I just used a flat head screw driver from the outside with a towel and pried the clips out from the outside of grill. While doing so just give a little push and comes off easy.
Now for the top i wished i had tried cutting just the grill out and not all of the bottom like instructions said. That way it would have probably clipped back in place and not show the paint in the back ground.
I just installed my upper grill tonight. I did like you were thinking, keep the bottom of the stock grill intact to avoid seeing any exterior color from the bumper behind the grill. Also ziptied the bottom and corners to the remaining bottom and corners for extra support.
It worked like a charm!! A bit of handywork with the dremel, but easy overall. Also, spray painted the A/C condenser and part of the radiator frame flat black whats behind the grill.
I'm happy with how it turned out.
Thank you for the write-up TOYSTRY, made it simple.
Dispense
Dispense, that looks sweet! Are you going to put the "Toyota" emblem in it? I would really like to see what it looks like cause I have the same exact truck and want to do it on mine.
Anyone out there with Photoshop?
Mark
Mark
TOYSTRY - Great write-up as followed it set-by-set to remove the upper grill and replaced it with the grillcraft insert. Looks awesome.
However, I did run into problems trying to removing the lower grill. I have a '12 TE and I cant seem to figure out how to get the lower grill removed by pulling out as I feel the Trail bumper trim is in the way of popping out forward.
What am I doing wrong? Do I need to remove the Trail bumper trim or drop the whole bumper? Should I try again but this time push the lower grill in towards the truck as opposed to out towards me?
Any suggestions would be greatly appreciated,
M
TOYSTRY - Great write-up as I followed it set-by-set to remove the upper grill and replaced it with the grillcraft insert. Looks awesome so far.
However, I did run into problems trying to removing the lower grill. I have a '12 TE and I cant seem to figure out how to get the lower grill removed by pulling out as I feel the Trail bumper trim is in the way of popping out towards me or forward.
M
Did you have to use a special paint to handle extra heat or anything? Also, are there any areas you needed to avoid when painting as to not ruin anything?
Don't paint the A/C radiator. You are going to decrease the efficiency of the radiator due to messing the heat transfer properties. Pretty much you are insulating the radiator preventing it from transferring the heat from the system to the outside air. The frame is fine to paint.
