How to keep DRL on
Is there a reason why you want these on as well? You can run with the fogs on when the headlights are on. You can even change the bulb to be more of a yellow tone (some people have done that here) to acheive the "lexus look" for the front end.
it just for fun. i just want the front corner bumper light to be ON at night. so at night all the front light are ON (fog, corner bumper light, headlight).
thank you kindly
snap315 said:
You Can't.
That is why they are called DAYTIME Running Lights.
Of course you can and part of the fun is finding out how. I would start with the electrical schematics to isolate the circuit and see what controls the loop.
i think i know how.
since DRL only use 1 of 2 fillament for DRL/Signal, maybe i can use the other fillament (i don't think it's used for anything because there's only 2 wires + -) and connect it to the parking light (the one on the headlight). So at night, i can have that light up and still have my Signal. At day time, it's just gonna be a DRL/Signal
let me know if i'm wrong
thanks
YSutarko said:
i think i know how.
thanks
Even easier hook to to the driving/fog lights since its next to it. You just have to leave the driving/fog (clear) light switched on.
...or you can forgo the schematics and use the search button. Look for a thread about enabling/disabling DRL. In there are instructions for adding a switch to allow to you to turn them on/off or put them in the factory default (auto) mode.
Rando,
OK, the light green wire with the red stripe at pin 12 ...
Thanks for your expertise.
Could you (or someone) suggest a 3-position switch for this that would fit into the available knockout?
Could you (or someone) suggest a 3-position switch for this that would fit into the available knockout? [/B]
You're on your own there. You may not be able to find anything with a factory fit but you can probably find something that can be custom fit into one of the switch blanks.
YSutarko said:
i think i know how.
thanks
You're not wrong. That is how I did it. Inserted a terminal for the unused pin on the socket and wired it to the live wire on the small parking light. PITA for some of the connections but all the wires are there to work with.
I guessing that the second [unused] filament would be lower wattage -- that typical for parking lamp brightness. This seems to be more ideal for nighttime usage.
I did the relay swap to get DRL and I understand I have only a single fillament bulb. Did anyone ever figure out why two filament bulbs are used for DRL optioned?
Regular DRL's at night are pretty intense. Anyone have real life experience with these on at night?
jeober,
A number of threads question the fact why a dual filament bulb was used on vehicle with stock DRL since only one filament is ever used, but I believe it still remains unanswered.
On another note...
People who do not have stock DRL, do not have 4157's in the front, they have 7440. It is a single faliment with a smaller diameter (more of a narrow bulb). The bad news is that the sockets are NOT the same size as the 4157 sockets, the 7440 sockets are smaller. This isn't a *real* big deal, since you could go with the 7443 (the dual filament counterpart) , but in order to do this mod, you would have to switch out the sockets to add 7443 sockets for access to both filaments. So, it may be a little more involved for those of you who have added the DRL yourself. Keep in mind I have an 04 Sport and believe that this would be the same across the board.
Tom
at night w/o turn signal
since DRL only use 1 of 2 fillament for DRL/Signal, i can used the other fillament (it's not used for anything because there's only 2 wires + -) and connect it to the parking light (the one on the headlight).
