How to lock center diff?
mike_da
I have an 08 V6 4WD Limited. What are the rules for actually locking the center? Are they the same as for engaging H4? Or do I need to be stopped in neutral like for L4?
On the fly is fine (preferred). Don't drive it on hard, dry surfaces with the center-diff locked. Dirt roads etc is fine but in general dry or wet pavement is NOT considered slick enough...
Thanks. That makes more sense. What about a very dry, hard dirt road? Does just being dirt mean there's enough slip possible to not bind up?
Hard packed, dry dirt may bind a little bit. It won't be enough to risk mechanical damage so yes, a hard, dry dirt road is fine. It may make it more difficult to disengage the lock.
If you did bind it a bit on a very dry dirt road you may have to make some shallow turns or stop and go D to R and back once or twice to complete the disengage cycle.
:cheers:
You can lock and unlock the center diff while stopped. If you do something stupid and get stuck and need it to get unstuck. Not that that I have ever done anything stupid :bravo:
If you are stopped and in D, but the center diff won't engage, switch the trans to N and then switch it back to D. You can also try the reverse gear. If it doesn't work the first time usually it does by the second. Just a future hint that may help somewhere down the trail.
