I am getting ready for the same thing, alot of the guys suggest the confed 2/1 or the daystar kits. I see alot of them talking about wheel spacers and triming the fenders too. So to add to your question...do we need the spidertrax and to shave the fenders?Just wanted to know what you guys recommend to level my 4Runner,going to get new rims and tires and think it will look better with a level look.
The easiest and most cost effective way is to install a small spacer lift in the front only. Most guys seem to be happy with a 1/2" spacer (gives 1" of lift) or a 5/8" spacer (gives 1.25" of lift) to give their 4Runners a nearly level stance.
I have the 1/2" spacer on mine and it looks much better than stock.
No, you don't need to put the wheelspacers on. Many prefer the slightly wider stance and improved looks. When you put the wheelspacers on you must do a minor fenderliner mod. Scroll down this page: [/COLOR]http://www.top4runners.com/ja/2007/wheelspacers.html
I agree. Think about and define "your level". Some define level as an equal amount of distance from the top of the tire to the wheel lip. Others think equal clearance from the rocker panel (F & R) to the ground looks best. Others just want a lot less rake. IMHO less rake or an almost level, when measured from the rocker panel to the ground, looks best. If you make the roff level it'll look like it's riding nose-up. I think 1-1.25 is perfect if you do the front only. This would be a good choice. This spacer provides closer to 1" rather than the .75" that's advertised. Front Top Plate Spacer Kit - Toytec Lifts: Toyota Lift Kits: FJ Cruiser Lift Kits, Tacoma Lift Kits, Tundra Lift Kits, 4 Runner Lift Kits, Sequoia Lift Kits, Toyota Truck Lift Kits
Have to agree with CJ3Flyr. A small spacer lift would do the trick, unless you have a reason to want to go bigger. I have the Toytec spacer he mentioned along with the stock front springs off a FJ Cruiser. I've not yet installed this, but it should yeild about 1.5" of lift in the front and level things out nicely. Toytec is a forum sponsor, and if you PM ToytecLifts you can get a discount code to use on their site.
