Chuckles89
This is a little guide I'm writing as a supplement to BFAD and drcoffee's write-ups. This is the part that a machine shop would normally do, but I'm too cheap for that (and up for a challenge), so I did it myself. This is going to be the first writeup for an ABS axle that includes the press work for the "backwards retainer" method.
Here is BFAD's thread: http://www.toyota-4runner.org/3rd-g...e-information-replacement-thread-3rd-gen.html
And drcoffee's thread about flipping the retainer: http://www.toyota-4runner.org/3rd-gen-t4rs/114743-possible-solution-leaking-axle-seals.html
Here are the new parts I bought:
Timken bearing with retainers (re-boxed NACHI Made In Japan)
Wagner Lug Studs (made in USA)
Doorman Wheel Cylinders (Painted black to prevent rust)
Toyota Outer Seal
Toyota Inner Seal
Toyota Snap Ring
Toyota O-Ring
Doorman ABS Ring
Wagner Brake Hardware (1 kit does both sides, made in USA)
Wagner ThermoQuiet Brake Shoes- notice they come with the pin installed
Since there are good threads about how to get the axle removed, I am starting with the axle shaft work.
Remove the brake shoes, adjuster, bell crank, wheel cylinder, and any other parts
Now you are left with this:
Put the nuts on the 4 backing plate studs and pound them out with a brass hammer or brass drift
Toyota Outer Seal
Toyota Inner Seal
Toyota Snap Ring
Toyota O-Ring
Doorman ABS Ring
