How to remove skid plate Nut in frame?
Greydog
Member
Do the dealer totally lunched a drill and tap for the DR bolt on the front skid plate. The hole is very oblong and a third of the nut is misisng, so tapping is not a great option,
Any ideas on how to get that captive nut out? There is an opening in the frame so it's possible to get a narrow tool in there, but it's a straight-in approach, no way to get any angle on it.
Torch it and chisel ?
I was thinking of replacing with one of those steel clips with nut on top.
Thanks for any suggestions.
Please post a pic or some pics. It’s hard to visualize w/o pics that drilling and over sizing is not the best option.
I used a hammer and punch that just fit in the frame and broke the weld loose. Then put in a Rivnut.
Really? How well is the RivNut holding up? I plan on doing the same thing when I order some new skidplates, since many of them use the existing bolt holes.
Also what size are you using? The largest I found were 8mm, though I'd like to bump them to 10mm if I could find some.
I replaced all with stainless machine bolts (washers & lockwashers) the same size on all the skid plates. I enlarged the holes on the plates and had no problems through 6 oil changes now.
I got the rivet nuts from McMaster Carr.
Since the hole is somewhat oblong due to the dealer drilling sideways it seems, I'm going to drill it out to a much larger hole and try to get the nut off.
If the nut is stubborn I'll try a Nutsert first, otherwise will try the RivNut.
Thanks guys.
Mine is rattling and I accidentally knock out one of the lock nuts for the bolt. I am also interested in the RivNut. How is it holding up thus far?
I never repaired it, been debating on a skids. So finally ordered a Man A Fre front skid which bolts to the front of the forward stock skid and again at the rear of the back stock skid, so it skips those mid mount points.
Jhunt
