How to remove the bottom screw of throttle position sensor?
JoeYello
It's a phillips head...but I can't seem to get anything in there to remove the screw.....anyone have any advice?
Are you talking about the IAC on the bottom of the throttle body? You have to remove the throttle body first, at least that's how I've been doing it.
I use a small bit out of a bit driver set and put it in a 1/4 socket with a 1/4 ratchet to get it lose and then just use the bit to remove it. reverse to install
The manual tells you to remove the manifold...
I tried to do it with a stubby screwdriver (before having access to the manual), but it was too long and ended up stripping the screw...
I went to the local hardware store to see if there was anything stubbier than a stubby screwdriver and found one of these:
Gifts for Guys
It's a pretty awesome little guy. Well built, versatile, easy to use, comes with a number of different bits (and they're the standard type so they're replaceable and you can use whatever special ones you need), has an adapter for 1/4" sockets, and comes with a little carrying pouch. I keep it in the glovebox to replace a number of screwdrivers and sockets. Saves weight and space while getting the job done. No affiliation whatsoever.
I use one of these to break it loose, and then just a loose phillips bit in my fingers to run it out.
BillM777
