How to replace battery in fob?
Okki
Not sure if it's in the user manual because I left that in the truck, but my fob has no range anymore, so I'm guessing it needs a new battery.
Anyone replaced theirs already? if so, how do you get to the battery and what kind does it take?
Okki
Okki
Here are instructions that I followed a while back:
Toyota Prius Smart Key Fob Battery Replacement Guide - 2010 To 2013 Model Years - Picture Illustrated Automotive Maintenance DIY Instructions
The only thing different is when it says to pry the two halves apart, use the physical key you extract from the smartkey system, not a screwdriver. The tip of the key should be flat and can insert into the notch.
Battery type is listed on the website as well, but you'll see it when you pop it open. If you can wait a few days, I bought my battery on ebay for a lot less than at the local store.
#1. Release Key by pressing down on the release panel on the side (it has a key insignia on the lever)
#2. Remove key by pulling chain with release panel open at the same time.
#3. Use flat pry tool (the end of the key works great) to separate sides of fob.
#4. Remove old battery.
#5 Replace with new battery (3V CR1632) in 2010 4Runner LTD.
#6. Snap sides back together.
#7. Reinsert key.
Okki
Thanks guys! .... added it to the maintenance section in my build thread as well.
Okki
Yep, it is in the owners manual and different for LE's and TE/SR5's with different battery pn's.My fob battery lasted about 2-2 1/2 years and they are cheap on Amazon so I went ahead and changed them in both fobs at the same time.
I never noticed the range decreasing, but mine was absolutely dead this morning. Push button start only beeped at me. Determined that the smart key battery was dead and happily remembered reading on here how to start the engine when the smart key battery is dead:
You just touch the Toyota emblem side of the smart key to the push button, wait for the sound, and then use the push button start like normal.
Yes, it is in the manual (p. 597), but I was very appreciative of the helpful information found on this forum when I was able to make my way to work without having to browse the entire manual... Until I got to work and realized I wasted a great excuse to take the morning off. :ohwell:
Thanks!
Thanks so much for this info! Bought a 2011 SR5 and the key fob was slowly dying on me! Great info and easy change of the battery!
youngrk
