How to replace your factory speakers... Lots of PIC!!!
Vegas
So not sure if any of you other new members knew this but there is other sections outside of the 5th gen forum... I know I don't like it either out there, it's scary and I can never figure out if the writeup I am looking at will work for the the 5th gen... Go JayBee did a great write on how to replace the stock speakers with lots of pics... Thought I would post here where most might be able to find it easily.
:Vegas
First off, here is a list of the speakers and material I installed:
Infinity Kappa 32.9cf (Dash)
Infinity Kappa 32.9cf 3-1/2" 2-way Speakers - Sonic Electronix
Infinity Kappa 652.9i (Doors & Tailgate)
Infinity Kappa 652.9i (6529I) 6-1/2" / 6-3/4" 2-way Kappa Speakers
NVX SDVK4 (6 Pieces)
NVX SDVK4 Versa Kit, 4 Sq Ft of Sound Dampening (1 18"x32" Piece)
Metra 72-8104 (Toyota Speaker Harness f/ Doors & Tailgate)
Metra 72-8104 (met-728104) Speaker Connector for Select Toyota
PAC BB-1PR (Bass Blockers f/ Dash Speakers)
PAC BB-1PR (BB1PR) Pair of 6x9 Bass Blockers / Passive Crossover
Now time for some pics:
Factory Speaker in Front Door
6 x 9 Hole
Factory Speaker Rear View
Front Door Panel Speaker Shroud
Speaker Shroud Removed
Dis-assembly of 6 x 9 Speaker
Internals of Speaker Removed
Speaker Mount Cleaned UP
More 6x9 Pics...
Sizing Up The New Kappa
1/4" Plywood Plates Ready for Cutting
One Done...
Two Done...
Speaker Mount Ready for Plywood
My Favorite Adhesive...
Ready for Clamps...
Waiting for Adhesive to Dry...Marking Center for Round Hole
Yet, More 6x9 Pics...
A Very Usful Tool to Have...
View from Inside...Good Adhesive Spread
Round Hole Cut, Plywood Covered w/ Sound Deadening Material, Speaker Glued Down
Ready for Mounting
Now, the Rear Doors & Tailgate...
Rear Door Speaker Removed
Wimpy Factory Speaker
Speaker Shroud - Before
Speaker Shroud - After
Factory Speaker - Before (Rear Door & Tailgate are Similar)
Factory Speaker - After (Rear Door & Tailgate are Similar)
Glueing New Speaker to Factory Mount
Ready to Mount in Door/Tailgate...Note the Grey Duct-Seal Used as a Vibration Dampener
More Rear Doors & Tailgate...
Rear Door Speaker Mounted
Tailgate Speaker Removed
Factory Speaker From Tailgate
Dash Speaker Connecting...see this link (post #162 by darkdane)
http://www.toyota-4runner.org/5th-g...ce-kappa-3-5-dash-speakers-11.html#post794787
For Mounting...see this link(post #217 by Kraeken)
http://www.toyota-4runner.org/5th-g...le-difference-kappa-3-5-dash-speakers-15.html
My install...
Factory Tweeter? Passenger Side
Another View
See That Blue Thing?...Don't Throw That Away!
Closeup of Factory Bracket
The Kappas...Plastic Ring Removed...Ready to Install
Shroud Removed From Dash Grille
Kappa Installed...Driver' Side
Grille Installed...Passenger Side
Driver's Side Front Door...Water Does Get in When it Rains
Pass Side Front Door Lower Section...Don't Block the Drain Holes at Bottom
Remove Styrofoam Block...Save for Re-installation
Place the Material Behind the Bracket
Upper Section Done...Don't Cover the Reinforcement Pipe
All Done...Vapor Shield Put Back in Place
Rear Door Finished
Ready for Speaker Install
yes, holy thread revival!
but why is this not a sticky (looking at you now [MENTION=66316]1engineer[/MENTION])? all the awesome information has been compiled here about how to change out close to all, if not all, the speakers, and even create mounting brackets to install different sized speakers.
so i ask again, why is this not referenced in the sticky?!
or this other thread
Improving stereo sound in 5th gen
these are great picture heavy threads...
Hey I just put out a post on updating the FAQ's and other stickies. If you have some that you think need to be in there make a list! I will be happy to add them as I get to the right place.
Thanks but tried that and theyre not coming off. Guess im going to have to bring them into a shop to fab brackets.
RennSport2UZ
