How to shut off factory alarm without fob? 2002
Lee in Texas
I bought my 2002 used, no alarm fob. I somehow activated the alarm and can't turn it off. This has happened before, but it has been a long time. I don't remember how to turn it off. I did a search and got some hits, but they all seem to leave out info; assuming the reader knows as much as the poster.
Can anyone give very clear instructions?
Also, can the alarm be permanently disabled or can I get a new fob?
Thanks. Lee
Finally got back to it. Did some more searching and saw a thread instructing someone to remove the black box for the alarm. I did that. It was under the dash, held in place with a zip tie, which leads me to believe it could be aftermarket. It doesn't say Toyota anywhere on it. There is a little white label that says "Main Module Part Number 00012-KU100. The car won't start now. It makes a rapid clicking sound. Is this from a dead battery (I'm trying to jump start it), or is this a problem related to removing the alarm box?
Thank you. Lee
Thank you. Lee
I would guess it's the starter kill circuit that's been activated or a dead battery. Removing the alarm usually involves more than just removing the brain but also re-bridging wires that were spliced into the alarm circuit too.
This is correct, I have an aftermarket alarm in mine too. Instead of pulling mine out, I turned the sensitivity to the lowest possible setting and that got rid of all the problems.
For future reference, locking the driver's door twice then unlocking it twice with the key resets Chamberlain alarms.
Thank you. Lee
That's the factory security module. Your truck will refuse to start without one installed as it was intended to have it. It can be wired around, buuuut.... not a great idea.
Key fobs are still available. There's a thread here about buying and programming new fobs to the truck: http://www.toyota-4runner.org/3rd-gen-t4rs/7501-programming-instructions-keyless-entry-remote.html
The fob you need has an FCC ID of HYQ1512Y for the 99-02 4Runner. They are readily available on eBay.
AndiGarage
