Hub crying?
collierunner
Ok, two weeks ago I upgraded to 5th gen calipers on the front with new Centric pads and rotors.
During that process the lower caliper bolt on the driver side snapped off; easy out broke off in the bolt. Went to the junk yard, got a new to me steering knuckle with 30k on it. It came with the hub and and everything. They had bent the crap of rock/dust shield carting it around on a dolly.
I bring the steering knuckle home and swapped the dust shields. I put a new axle seal in and bolted everything up. Used the hub that came with steering knuckle, used the o ring seal that came with the steering knuckle/hub.
I then drove the 4runner from Portland to Helena Mt to see my little brother and then on to Glacier, then back to Portland. Before leaving Glacier I'd started to hear a squeak now and then, like a bird chirp, but very quiet. Only while going really slow.
Now that I'm home if I have the window down and at very low speed, pulling into a parking spot, in and out of the garage. I hear a very quite cry from that front driver side wheel. Its one of those noises where I'd doubt anyone else can hear it but its driving me nuts. There is no noise above 5 mph.
Its making me wonder if I reinstalled the hub wrong while swapping the dust shields. Anyone heard a cry from a hub before? Or did I reinstall the axle wrong? not tight enough or too tight? I replaced both front axles before with out any issues. Thanks for the help.
List of repairs I've complete in the last year:
Rear driver axle seal/breather
Rear driver stuck caliper
Both lower ball joints
Both Front axles
All the fluids/plugs
Serpentine belt
I have had that screeching sound when I've plowed through heavy snow off roadding.
Ramped it up, and pulled the shield away by hand has cured it.
My hub started squeaking like you describe, then it got louder, turned into a hum, then a drone, then a rumble, rumble (this sounds like a bad song or something...).
Anyway, it was a bad wheel bearing for me.
Well at least you have a replacement hub already.
This is true.
But the 30k hub spun so much smoother than the original 140k hub. Honestly I was hoping to someone would tell me the seal didn't seat correctly-Take it apart try again.
I bent the shield away from the rotor when i first heard the sound. I'll take a long screw driver and pry some more for kicks.
I had a similar noise and I was freaking out since I had just changed both front hub bearings a few months ago. The noise ended up coming from a seal on the CV shaft where it mates to the seal on the back of the spindle. I just slid the cv axle seal back up onto the cv and the noise went away.
I have two hubs I just took off with 130k and they are both going back on fwiw... they are not worn so I'm not replacing them.
Sent from my SAMSUNG-SM-G900A using Tapatalk
DionicioLives
