Hyde builds some axles.
Fuel pumper died. This was my no hot start issue.Took the opportunity upgrade a little. Its a summit racing 12 gal cell with an Airtex E2000 external pump. Fuel pump is mounted in the angle iron that was the old tank mount. It also allowed me to move my tool box for better access.
temporary_zps2ioekeuk.jpg~original
temporary_zpsdluzdaep.jpg~original
temporary_zps450qmqad.jpg~original
temporary_zps9oj6o3ne.jpg~original
Drove down the road to a friends shop to pick up some parts and catch up, also did a little flexin. Its a 36" tall ramp.
temporary_zpsqqyjqsw3.jpg~original
temporary_zps0v82irr3.jpg~original
temporary_zpskuotolvx.jpg~original
temporary_zpsdbibpenp.jpg~original
Had to take the winch completely apart to get the rusted motor out. It was seized into the bearing, which was crunchy sounding too. The DB electric motor came with a new bearing, so it went back together.
temporary_zpsieeixngk.jpg~original
temporary_zpsiciptgon.jpg~original
My fiance and I just bought out first house. Nice little 10 acre chunk in Northfield VT. Mostly field but some stuff to play on, and eventually there will be a rock course some where on the property. But what Im most excited for is that for the first time in 5 years, my truck is at where Im living. And I have my own garage. And as soon as I get it set up I can get the truck in and get working on some maintenance issues!
Leaving my folks shop in Royalton, just a short 30 min tow. It will be back in November for a trail ride here.
temporary_zpszyxqwulb.jpg~original
In front of my own garage!
temporary_zpshj19c47a.jpg~original
temporary_zpso11qccyr.jpg~original
WP_20150830_017_zpsyvbgmlfd.jpg~original
Made it 10 min into our Dec run and the front r&p let go. The front end bounced and when the spinning wheels hit the ground it was all done. ting ting ting ting.
Walked the rest of the day and then dragged it home to get fixed.
WP_20151212_12_24_14_Pro_zpsc5jzc4nq.jpg~original
WP_20151212_12_24_03_Pro_zpsvjoyhxlb.jpg~original
Used 4.10 3rd, welded up and ready to go.
WP_20151209_20_28_16_Pro_zpsqy0xohq4.jpg~original
Trucks back together and weve been having some fun with it around here. Its going back in the garage soon to have the t case pulled and sealed, because its leaking out of everywhere.
Pulling the oil tank our of the basement with the winch.
WP_20151025_001_zpshtl4xlk4.jpg~original
WP_20151012_001_zpshl8p5nlp.jpg~original
And with the little bit of snow we have
temporary_zpsldbcfpwd.jpg~original
temporary_zps4q0yjhl3.jpg~original
temporary_zpsqg8ubrpi.jpg~original
And just driving around.
With the first gathering of the season right around the corner, time to get some maintenance done. First is to address the leaky t case.
temporary_zpsyneyo8g4.jpg~original
And a little tear down.
temporary_zpsm3rbzohn.jpg~original
temporary_zpshjbridsa.jpg~original
temporary_zpsx4nzr4bn.jpg~original
Time to start cleaning and re assembling.
I just take my time, and the Trail gear instructions are pretty helpful.
Some re assembly, but had to stop when I found the splines on the front output were twisted! Oops. Probably happened when the front ring and pinion went last December.
temporary_zpsf53joorx.jpg~original
Reduction gears
temporary_zpsgsplwqlm.jpg~original
temporary_zps4orhg7gq.jpg~original
Twisted splines
temporary_zpsr1qzwwx6.jpg~original
Ill be picking up another case tuesday for parts and get it back together.
Pulled the "new" output shaft out of the donor case, and got a little more assembled on the good case. Should get it finished up tomorrow.
temporary_zpsxqyccp2x.jpg~original
Little more wire brushing and well have it back together. 1/2 way done with the one on the right, still need to do the left case.
temporary_zps2l6r6fnw.jpg~original
T case together and cleaned up, and back in the truck. Ill throw the drive shafts on tomorrow after work and take her for a spin!
temporary_zpsjrpfbzaw.jpg~original
temporary_zpsamkytgqi.jpg~original
Took the time to through bolt the pass side engine mount to match the drivers side. 1/2x3" grade 8
temporary_zpshkgzauop.jpg~original
Retorqued the high steer arms and ubolt, greased the drive train changed the tranny fluid, went through and organized recovery gear. Shell be already for a little wet spring wheelin next weekend! Even washed and vacuumed the inside!
Finally getting nice enough out I can wrench with the door open again.
temporary_zpsvzkwnh4u.jpg~original
Wheeled a few weekends back, same place as before. The Jungle in Bethel Vt, it was much wetter but nothing broke.
WP_20160612_12_29_56_Pro_zpscx0bis4p.jpg~original
WP_20160612_12_36_32_Pro_zpsa3da6iyl.jpg~original
WP_20160612_13_31_56_Pro_zpswenam2ni.jpg~original
Headed out again this weekend to Field and Forrest Rec Area in Southern NH.
Hey, quick question for ya! How do you like that Miller 180? I had a 175 but they don't sell it any more and I'm going to be in need of a new welder for my other project car.
Was thinking of trying the Esab, but not sure I really need all those bells and whistles, seems to just be more stuff to go wrong.
Oh yeah, awesome trail rig!
Hey thanks! The 180 is pretty sweet, does everything I can throw at it. My step dad uses it a lot more than I do and he has no complaints.
Not a lot of news other than a wheeling a bunch. After 2 years of wheeling on them, my RUFs are shot. Going to replace with some Old Man Emus.
Old bastard pack made from 2 or 3 other 48" rear 4runner springs. New springs are 2" lift for same said 4 runner (cs009r). I may have to modify them a bit, but it gives me a great pack to start with. Paying with ride heights tomorrow night.
Springs are on. I pulled the long overload but left the short one. Got about 3" of lift from them over my old springs. The spring clamp may hit the pitman arm, so ill have to watch that when flexing it out tomorrow.
IMAG0651_zpskohcxtfk.jpg~original
IMAG0652_zpsmbbmqqa5.jpg~original
And a couple wheelin pics from the summer.
IMAG0562_zpszjk5xu0h.jpg~original
IMAG0532_zpslzg0tb6h.jpg~original
WP_20160625_11_16_43_Pro_zpsovh8tycj.jpg~original
WP_20160625_15_25_41_Pro_zpslj3celhb.jpg~original
WP_20160625_19_35_02_Pro_zpsudaf7emo.jpg~original
(Im neither of those guys)
WP_20160626_11_00_03_Pro_zpskhntihgt.jpg~original
2001ATL
