Hyde builds some axles.
Passenger frame plate and motor mount burned in. When the shock mounts go on, they will brace to the motor mount too. I *may* have gotten a little torch happy in that area.
temporary_zps200e4572.jpg~original
And drilled out the hubs for the creeper flange pins.
temporary_zpsa46addda.jpg~original
Going to try and knock out the steering box mount and drivers side frame plate this weekend.
Had a heck of a time finding longer wheel studs. Didnt want to drop the $$ for ARPs and they dont "just make longer studs". So this is what I found:
Dorman Part #98458 is the stock front stud is a .559" Knurl and a .3149 shoulder depth. Length of 40 mm.
Part # 610-312 is a stock rear stud, with a knurl diameter of .5578" and shoulder depth of .4921. 44.5mm long
But after digging through the Dorman parts book, I found one!
Part # 610-463. Rear stud off of a Awd Toyota Matrix. Same .559 knurl but a shoulder depth just over an inch, it makes the whole stud 55mm.
Stock on the left, stock rear in the middle, and martix on the right.
WP_001525_zps03db03b0.jpg~original
Same with the Taco rotor on.
WP_001526_zps0b5f633a.jpg~original
And in the rim
WP_001528_zps9bf389e5.jpg~original
I can get about 6 turns onto a stock one, and about 8-9 on to the stock rear. this bolt is .75" long and I have thread for days.
WP_001531_zps8cbd9836.jpg~original
Probably could have gotten away with using the rear studs, but I wanted to be sure. Plus, the matrix studs longer shoulder gives a nice place for the rotor to ride on.
With that out of the way I put the front axle together.
WP_001532_zpsc65f4fd4.jpg~original
Still need to work the break shims to get the rotor to line up with the caliper. but still.. :boink:
WP_001533_zps3c5fabb2.jpg~original
Run down of the axle: 85 Axle with all the TG armor. Marlin axle rebuild with Koyo wheel bearings and Youkon trunion bearings. Ifs hubs ground down with martix wheel studs running 97 Tacoma rotors. Stock 92 v6 break caliper moved to the other side of the knuckle ears and drilled out for 1/2" bolt. 5th stud. 4.10 diff with lunchbox locker and 30 spline longs with TG creeper flanges.
Test fitting the steering box. Steering is supposed to be in Thursday, then I can finalize everything.
temporary_zps69b8ddb3.jpg~original
Thanks for stud info. I like the pitman arm clearance hope to get mine that close.
It looks like the nut on the tie rod might have some clearance with the frame.
Got most of my steering parts in yesterday. Ill have a better update after the weekend, but heres the teaser.
temporary_zps903ec215.jpg~original
are you planning to run some inset wheels? the scrub with that set-up is going to be bad. steering effort will be very high.
im building a front 60 so I can do just the opposite, and get the tire more centered over the steering axis.
nevada-I wont be running wheel spacers (IFS hubs), so Its actually just narrower than a stock 85 axle with 2" wheel spacers that everybody and their brother runs, So I should be fine.
Brif- Thats the plan! I should have pics of it together after the weekend.
I hope it works out for you.
its hard to tell but by that pic, it looks like the center line of the tire is going to be way outside the trunions.
I have this going on with my truck. im running very deep backspaced wheels, the scrub is terrible, steering effort is HIGH, and being spooled, turning sucks. it pushes badly.
Heres some comparison pics. These are RuffStuff 7/8th hemis vs the stock 85 tierods.
WP_001548_zps479f667b.jpg~original
WP_001549_zps28826dc5.jpg~original
WP_001558_zpsb75439b8.jpg~original
Mock up.
WP_001550_zps3408cae9.jpg~original
Going to notch the frame for the bolt. I got it to sit a little tighter, but the overall length of the hemi with the misalignment spacers and bolt is pretty long..
WP_001555_zps63d718c4.jpg~original
Had to take just a hair off each washer to get the calipers to sit perfect, and they JUST barley clean the inside of the 15" rim. . Tierod is done, but waiting for one joint to come in before I can finish up the drag link.
WP_001559_zpse290d19c.jpg~original
With the wheel on
WP_001554_zps88a4fadd.jpg~original
brifri- I had to cut out the back of the core support, but the front is still there.
Got my tanning booth set up
WP_001575_zps6f33333c.jpg~original
Got the frame finished and boxed on all sides and mounted the steering box.
WP_001582_zps6fda51b0.jpg~original
Like a glove.
WP_001583_zpsf2f42e4b.jpg~original
And the other side. I trimmed the smaller spacer on the drivers side for more up travel but didnt do this side because I didnt need to, but it looks pretty goofy being so tall. There is about 1/8th of an inch between the hemis at the closest point. Plenty of room!
WP_001584_zps7eb91569.jpg~original
Steering is done, just add fluid.
Shes sittin on all 4s.
WP_001604_zps4984aa6a.jpg~original
Tire to tierod clearance.
WP_001605_zps68f908ba.jpg~original
WP_001606_zpseaee5d5c.jpg~original
WP_001607_zps56db532f.jpg~original
WP_001608_zpsa4609c38.jpg~original
Front had 2ish inches more to droop, other side can go up about another inch. Ill get final travel measurements tomorrow so I can figure out what I need for shocks.
Looks great Hyde. Flexes good. Did you flex it to see if the sector shaft hits at full stuff? I'm trying to decide on my placement, and whether it's worth notching frame.
Flexed it out a little better last night with the help of the excavator. Looks like the 12" shocks will work fine for me. Pitman arm clears the frame/springs fine, but the draglink starts to hit the frame on the pass frame rail just after the leafs start to go negative, so instead of notching the frame, Ill just bumpstop it and call it good. The drivers spring hit the bottom of the hemi before the tierod hits the frame, so im going to try grind down the mis alignment spacers a little more, so I should be good there too.
The chevies dont flex as well as I would have liked, but there is no weight back there so ill wait a bit before looking for a different set of springs.
WP_001613_zpsadb135fe.jpg~original
WP_001609_zps87b6b695.jpg~original
WP_001614_zps15d9294b.jpg~original
WP_001615_zpsed069f96.jpg~original
WP_001618_zpsbfc81955.jpg~original
Intake is a little wonky, but it cleaned up the engine bay, which is what I was after.
WP_001620_zps56b30d77.jpg~original
Front shock mock up. They are the 12" ford shocks with ford shock towers. Set for 3.5" up travel and 8.5" down. Should be plenty of travel.
WP_001627_zpsac10e4c3.jpg~original
Finished pic, Bumpstop is some small daystar (or something) on the spring plate, and bumps against the frame, just before the tie rod hits it.
WP_001629_zps39e8345b.jpg~original
Rear shock setup. Same Ford shocks and towers, but cut the towers down to fit.
WP_001635_zpsbb6c8702.jpg~original
Made a square shaft out of 2 single joint yokes. Used 2.5" Receiver tubing (no inside seam) and some 2" .25 wall tube for the inside part. It required re drilling the mounting pattern on the t case output, but wasnt a big deal. . (more angle than a clearanced CV joint, 42 vs 35) And took it for a drive!
WP_001636_zps2218c25b.jpg~original
I need to get a small piece of gas line tomorrow after work, but expect some action shots soon, and plans are now being drafted up for a bed/cage
WP_001637_zps0f18f9ac.jpg~original
WP_001638_zpse326df82.jpg~original
WP_001639_zps5552d6b2.jpg~original
WP_001640_zpscb90afa8.jpg~original
alexaturner
