Hyde builds some axles.
Got some moar, other peoples pics.
Trailer line up
trailerlineup_zpsfde1290b.jpg~original
bluetrucklead_zps2d8e450a.jpg~original
First hill into the property
Second Hill, thats the jeep with the dead battery.
nextinline_zps4324907e.jpg~original
Faster than the camera..
winch1_zps6c8a7d86.jpg~original
winch4_zpsda5bfb08.jpg~original
winch3_zpscf675212.jpg~original
winch2_zps451c0251.jpg~original
winch5_zps28a911d3.jpg~original
After winching up that hill and a short one right before it, I needed to let my battery charge back up. While doing that we hooked the next guy onto my rear mount and started bringing him up the hill.
winch6_zpsac83578f.jpg~original
Man what a great day.
sweet pics man! did i read that right that you got 15" wheels to clear taco rotors? i've been looking at doing that but i keep reading that you have to go with 16" or bigger wheels and i don't have the $$ for that
Thanks man! Im still using the 92s calipers, and they clear the inside of the 15" rim with about 2-3mm to spare, just as they would have done when it was IFS. I think you need a 16" rim to run taco calipers. I did have to widen the caliper a bit to get the taco rotor to fit in it. IIRC the tacoma rotors do not have a bigger diameter than the IFS rotors.
WP_001555_zps63d718c4.jpg~original
All the info is a few pages back.
Quick bath, to get it ready to go back in the shop to address a few things. Motor mounts and engine leaks are first, then I need to change around my front leafsprings, then I can finally finish up the half doors.
WP_001753_zpscd5eb3aa.jpg~original
Here you can see where the thicker newer Downey springs arent bending as much as the softer worn 48" spring. Im going to take them out and change them up a bit.
WP_001754_zps64308718.jpg~original
Got a killer deal on a forward shift, that ill convert to a top shift.
WP_001748_zps7acffad1.jpg~original
Maybe this winter. Trucks wheelable now, so Im gonna drive it as much as I can this summer, then well see where we are. I havent even picked up the donor truck yet.
So yeah.. I bought a 2000 s10 with a 4.3 and a 4l60e thats gonna end up in the truck, probably with stock ratio duals. But well see as I dig into it. :biggrin1:
And one more pic..
slickrock_zps8d3703fc.jpg~original
Heres the crooked engine, that led me to find the broken motor mount. That and when I hit the gas the shifters went about 2 inches to the passenger side.
temporary_zpsfea81ef5.jpg~original
Drilled and put a 1/2 inch grade 8 bolt through it, Marlin style, tightened the nut till the lock washer closed.
temporary_zps9a6ab6ea.jpg~original
temporary_zpsf2794470.jpg~original
You dont have to pull the mount off the engine as long as you can unbolt the rubber part, I did because I didnt know, and it makes it easier to get to the nut. The hole in that engine side mount is already 1/2". But if you do decide to take the mount off, you have to pull the oil filter and dip stuck tube to get it off.
temporary_zps208c491e.jpg~original
temporary_zps062f06ca.jpg~original
At least your engine was bolted down. My 3.0 wasnt bolted down and it only had 4 of the 6 bolts in the bellhousing and 2 of those were loose lol.
A few final pictures from the run in April.
pic3_zpsf061e684.jpg~original
pic2_zpsf7954ac6.jpg~original
pic1_zps8f3357df.jpg~original
Ive been lazy lately now that it bike season, but got some time in today. The screen in the feed line of the powersteering line was clogged, which would only allow about 3/4 turn of the steering wheel in either direction before squeaking and fluid loss out of the cap.Cleaned it out and were good to go again.
WP_001805_zpse833970c.jpg~original
WP_001808_zpsf5313d7b.jpg~original
WP_001809_zps293fb4e7.jpg~original
And did some trail scouting. Each one of those ledges is about 2-3' tall. Going to get a trail cut to this spot soon..
WP_001802_zpsa6e03dc1.jpg~original
Changed out the front lead packs for a different ruf pack and did a little cruising around tonight, have a couple buddies coming over sunday to do a little cut/wheel day.
WP_001861_zps90b1fad3.jpg~original
WP_001860_zpsaa08ffda.jpg~original
WP_001863_zpsd0ffa4d2.jpg~original
WP_001864_zps5ca5b157.jpg~original
WP_001865_zpsf31d645b.jpg~original
WP_001866_zpsd1c1afb2.jpg~original
And I got a little stuck...
WP_001868_zps5021a399.jpg~original
WP_001869_zps2d06e595.jpg~original
Should have some good photos after Sunday too!
I just wasn't to know how you broke the mount on a 3.slooooww it's not like the power broke it
Hyde just curious what changes did you make to the ruf pack? Also I'm setting up my shocks on the front very similar with 3.5 up and 8.5 down. How does that work out for?
ive seen this type of a thing a lot, but I cant understand WHY?
I have my front shocks fairly centered, and I use a LOT of the up travel, much more than 3". I don't understand why I would want to limit the up travel.
also, [MENTION=69539]Hyde802[/MENTION] how is the tire scrub with that front hub set up you're running?
Having a ifs frame I limited by up travel a lot. But also running a thin five leaf pack of rear springs, nearly flat at ride height. So if running a lift spring you could have more up travel.
Hyde also curious about the scrub radius as I have the taco swap so add a .5 inch overall.
The shock length is working well. In the pic above with the frond drooped, the wheel can drop another 3" or so. I ended up with a solid 3" of uptravel, Yup, gotta love the IFS frames. Draglink hitting the frame on the pass side, and pit man arm bolt on the drivers. But I dont bottom out much, Havent jumped it yet though. And it stuffs the 38 perfectly. If I had more uptravel, I would need smaller tires or less sheet metal.
I swapped out the RUF for a 6 leaf pack that some one else had already put together... Same ride height, just the springs pack better together.
Scrub is not bad, steers as sharp as any locked F&R vehicle does. But not bad for a stock steering pump on 38s.
Only got about an hour of wheelin in before the front ring and pinion decided they were done. Ive never check the ring and pinion part of the diff, felt good so I ran it. I have a solid spacer kit on the way and ill re build with other 4.10 parts I have.
WP_001875_zps39afb485.jpg~original
I dont know when it broke? But When I got in it to move it again it wasnt happy.
Gettin the strap out.
WP_001889_zps48c00ce4.jpg~original
WP_001890_zps72fa3842.jpg~original
I have way to many pictures of my truck on jackstands.
WP_001891_zps3bd86e40.jpg~original
My buddies runner:
WP_001878_zps1126a438.jpg~original
Toyota width trails
WP_001881_zpsbc448d51.jpg~original
BillM777
