I built a Prinsu Style Roof Rack for $300 - Here's the How-To
[MENTION=436994]SuperfastMatt[/MENTION] inspired me to build a roof rack for my 4runner. I used the same materials as he did. I spent close to $500 since I had to buy everything online. Shipping costs add up quick! Here are some pics.
Can you post a link to the parts, I will need to get them all online also.
Do the stock rails not work for some reason? I would just need the inserts and the front wind dam.
The stock rails only cover about half the roof length and are only rated for 165lbs I think. You cannot hook up the extruded aluminum bars to the stock rails
side rails and front wind deflector - Supplier of steel, stainless steel, aluminium and hardware products in Los Angeles, CA, USA | Bobco Metals
3003 Aluminum Sheet - 0.063
SKU: AL03SH.0634X8-custom-size
Width: 8 Inches X Length: 48 Inches Qty: 1
6061 Aluminum Flat Bars - 1/4 Inch X 2 Inch
SKU: AL61FB.250X2.00-custom-size - 8 Feet Qty 2
crossbars: TNUTZ | Your leader in T-Slotted Aluminum Hardware & Components
EX-1020-BLACK - 1" x 2" Smooth T-Slotted Aluminum Extrusion - Black Anodize
Length (in): 47, Quantity: 10
Others:
McMaster-Carr
McMaster-Carr
McMaster-Carr
https://www.mcmaster.com/#4869A71
https://www.mcmaster.com/#8982K61
https://www.mcmaster.com/#97763A267
https://www.mcmaster.com/#96765A140
https://www.mcmaster.com/#94407A104
Others:
McMaster-Carr
McMaster-Carr
McMaster-Carr
Can you provide the link for the bolts to bolt the rack to the truck? I'm guessing some 3/8" inch bolts but how long? 1.25"?
I don't know if it makes a difference but I'm doing this for a 4Gen 4Runner.
Actually I was searching for the DIY idea for the very same reason for the low cost roof rack for LX470. This is exact what I'm dreaming.
Thanks for sharing!
How did you cut the angle pieces and is that JB weld?
How does it hold up? Really digging the look of it.
