I love a good rig job!
Millerad1651
So my exhaust has been driving me crazy lately. One of the rubber hangers broke, so the exhaust pipe sat on the frame crossmember. Every bump I hit, the pipe would bounce on the frame...very annoying.
So I looked under today, and created a solution...a really really cheap solution.
I took a 3/8" x 3" bolt, and threaded a nut on the end. Then i wedged the bolt under the exhaust pipe to aact as a spacer. It actually pushed the pipe up, which helps keep it in place. Then I took some wire and wrapped the bolt around the frame to keep it in place.
Drove it home and voila, No Rattle!!!
IMG_0863.jpg~original
IMG_5315.jpg~original
IMG_2818.jpg~original
quick, easy, and cheap...we'll see how long it'll last.
That will quiet down the rattle... but eventually, that bolt will cut through the exhaust pipe....
If you go to a small Exhaust shop, they should be able to fix that for $20.00, just add a hanger....
You think it will? Its been sitting on the crossmemeber banging up and down since last November, and there isn't any damage to the pipe. I figured with no movement, it should be fine. I'll check it in a couple weeks and see how its going.
I do plan on getting a new cat back put in later this year (the muffler has a couple small holes...its original) so until then I'll probably just leave this.
Thanks for the advice though.
Is it gheto? Or ghetto? LOL, at least you didn't use a pink wire clothes hanger like I've done in the past. Jeeze, thinking back to all the rigged up exhaust calamities of my teens....
I just gotta ask... Why would you take one minute out of your life to take a picture of that, let alone post it???:wtf:
charlesz
