I need your help...
bluewavecaptain
So I'm working on my 3.slow project. I plan on removing the heat shield on the crossover pipe and wrapping it in header tape. If I leave the clutch fan bracket off, the radiator out, can I install the short block with the cylinder heads and exhaust on or should I install the block, and then, the cylinder heads afterwords...
I would definitely hook up as much as you're willing to wrestle beforehand--it's a LOT easier outside the truck. I did the V6 in my first 4Runner with nearly all hard parts attached--just walk it in slowly, with a couple friends to watch the sides for obstructions.
... If I leave the clutch fan bracket off, the radiator out, can I install the short block with the cylinder heads and exhaust on or should I install the block, and then, the cylinder heads afterwords...
Have the engine assembled as much as you can, it's definitely much easier to do it all while the engine is on a stand, vs in the truck.
Gonzaga Lobos
