ICON 5th Gen Suspension - T4R Best Buy
Popular Suspension Systems for T4R Enthusiasts
Total Automotive Performance is proud to offer the entire
ICON Vehicle Dynamics Suspension Systems and Products.
We are an ICON Authorized Dealer with nothing but
positive feedback from our T4R customers.
We offer individual suspension components, as well as,
complete ICON Systems.
We can also mix & match to help with your perfect build.
Feel free to browse our ICON 4Runner Kit suspension listings HERE.
Everything you need from Complete Kits, Stage 1 to Stage 7, to
your very own 2.5 Bundle, ICON Vehicle Dynamics
has the items needed for Daily Driver Comfort and Off-Road Performance.
Contact Us via PM, Online Chat, Phone at 702.979.1577
email [email protected]!
Get Started on Your Order Today!
There was a huge response to the ICON Suspension Systems - Thank you!
Our Fulfillment Team worked hard getting everyone equipped for the Overland Expo,
then Memorial Day Weekend.
ICON Complete Kits and 2.5 Builds were HOT MOVERS over the weekend.
Current Production Time at ICON 5-6 weeks.
Please contact us for in-stock availability.
Let us know how we can help.
_
ICON Vehicle Dynamics has developed a tubular uniball upper control arm system for the
2003+ Toyota 4Runner 2wd or 4wd.
Weak OEM ball joints present problems by limiting suspension travel.
ICON 1” PTFE Lined Uniballs combined with 17-4 Stainless Taper Pin Adapters increases the
upper arms misalignment, allowing for smooth and clean wheel travel without worrying about
factory ball joint bind.
Take the performance of your 2003-UP Toyota 4Runner to new levels with the ICON Vehicle
Dynamics Delta Joint tubular upper control arm kit.
All ICON tubular upper control arms are constructed from CNC bent 1026 DOM steel tubing and
then powder coated to a semi-gloss black finish for maximum strength and corrosion resistance.
ICON's patent pending Delta Joint is a heavy duty high angle ball joint that combines the durability
of a ball joint with the performance characteristics of a traditional uniball.
ICON billet upper control arms are constructed from CNC machined 6061 aluminum and then
finished in a matte anodization process for maximum strength and corrosion resistance.
ICON billet aluminum upper control arms feature quality PTFE-lined rod ends and machined adjuster
sleeves that allow for on-vehicle alignment adjustment and precision caster and camber tuning.
ICON Upper Control Arms (UCA's) are combined with the 2.5 Series coilover shocks, the Extended Travel
version, to provide increased wheel travel that will enhance your on and off-road performance even more
so than the standard travel units.
_
ICON 2.5 Coilovers and 2.5 Shocks are on Fire!
This is quickly becoming one of our most popular ICON bundles.
*When ordering online, use Promo Code "T4R" for added savings on most brands.
_
ICON is working hard to get their Production Times back in-line at 3-4 weeks.
Stage 1 and Stage 2 Complete Kits are In-Stock, but go quick!
Don't forget the Spanner Wrench, Part #198000, if looking to make adjustments to coilovers.
_
ICON Hot Mover!!
Stage 5 Kit has been a popular choice this month.
A Perfect 5th Gen Labor Day Build for sure - Click Here
SYSTEM COMPONENTS:
58747 - EXT TRAVEL 2.5 VS RR COILOVER KIT
57810P - 1-3" REAR 2.5 VS RR (PAIR)
58451DJ - TUBULAR DELTA JOINT UCA KIT
54000T - TUBULAR LOWER TRAILING ARM KIT
52700 - REAR 2" SPRING KIT
WHEEL & TIRE FITMENT INFO:
- OEM Wheels & Tires: Yes
- Aftermarket Wheels: 8-8.5" Wide, 4.75" Backspace
- Aftermarket Tires: 33" x 11.25
- (Larger tires may fit but fender trimming and modifications will be required)
OPTIONS:
56100 - ICON Rear shock shin guards
54100 - Billet upper adjustable link arms
54200 - Adjustable track bar
52800 - ICON Overland Series dual rate 3" lift rear coil springs
56104 - Rear hydraulic bumpstop kit
191011 - ICON tubular upper control arm cover caps
198000 - ICON 2 pin spanner wrench
*Adjustable track bar, Part #54200, is recommended for KDSS
Order Today - Click Here
_
ICON orders are all over the place, which is awesome.
From Complete Kits to Custom Builds, we have you covered.
Need help putting together the right build, give us a call or send us a PM.
We are here to help.
_
Looking for ICON Suspension System?
Now is a Great Time to Buy!
Most orders are shipping within 1-2 days.
Billet Upper Control Arms (UCA's) are on order and about 1 week on shipping.
The Popular Stage 1 and Stage 2 Complete Kits are shipping right away.
Looking for a Stage 7 Kit - Click Here
_
While supplies last.
Looking for ICON?
Most items are shipping within 1-2 business days.
*While supplies last
Feel Free to Contact Us for Pricing on 4Runner Bundles, Complete Kits and Availability.
_
We get asked all the time about what is needed for KDSS.
Adding the Adjustable Track Bar, Part #54200, is recommended due to the travel of the rear shocks.
This Adjustable Track bar for the FJ Cruiser is the best way to optimize your 4 Wheel Handling and Wheel Alignment.
When your track alignment is off center it can cause premature tire wear and have as precise articulation. This bar is
an easy install and can be finished in a couple of minutes and can easily be adjusted on the truck without having to
take it on and off.
KEY FEATURES:
- On truck Adjustability using ICON's pinch housing"
- 3/4" Rod End and Polyurethane Pivots, for excellent strength and longevity
- High Misalignment Spacers for Excellent Articulation
- ICON Vehicle Dynamics Life Time Warranty
- Made in the USA
_
Don't miss out on our Annual SEMA Specials!
For Promo Code and a Complete List of Brands - Click Here
_
What an Amazing Black Friday thru Cyber Monday.
All ICON orders have been processed and shipped - Woot!
If you are looking to get an order shipped before the end
of the year, now is still a great time.
Cyber Monday Most Popular Item - Stage 5 Kit, Part #K53065T - Click Here
SYSTEM COMPONENTS:
Front 2.5 Coilovers, w/Res - Part #58747
Rear 2.5 Shocks, w/Res - Part #57810P (PAIR)
Delta-Joint UCA, Tubular - Part #58451DJ
2" Rear Coil - Part #52700
Rear Lower Trail Arm - Part #54000T
_
2019 was an Amazing Year and ICON led the pack in off-road suspension for Toyota.
For everyone looking to start the New Year with ICON for their 5th Gen 4Runner,
we want to add something special.
For all orders of Complete Kits and 2.5 Bundles, we want to provide you with a
Free ICON Shirt of your choice.
ICON Complete Kits - Click Here
ICON 2.5 Bundles - Click Here
Just add to the notes the shirt and size you want and we will add it to your order.
For a Complete List of ICON Shirts - Click Here
When ordering online, use Promo Code "T4R" for added saving son most brands.
_
ICON is one of the Most Popular Suspension options for Toyota.
This includes Tundra, Tacoma, FJ Cruiser and 4Runner.
We receive a lot calls, emails and PM's from both T4R members and non-members regarding
Stage 1 vs Stage 2 Complete Kits.
The cost for Standard and Extended Travel coilovers are the same, but Extended does require
the addition of an Aftermarket Upper Control Arm. This added investment is worth taking into
account for your Daily Driver and Weekend Warrior needs.
These adjustable coil-over shocks have proven their strength and longevity for years.
Standard and Extended Travel coilovers offer the best ride quality and handling. They
increase suspension travel and dramatically increase the capabilities of your 4Runner's
front suspension.
Extended Travel Coilovers are meant to be installed with an aftermarket UCA to ensure
the proper amount of wheel travel and to prevent premature ball joint wear.
ICON Coil-Over’s come complete with all the hardware necessary to complete the installation,
as well as, a sway bar relocation bracket kit to adjust the location of the sway bar to clear the
larger shock.
Technical Specs:
- Adjustable ride height from 0" - 3.5"
- Race shock piston with flutter stack compression valving
- Kit Includes Sway bar relocation brackets
- Cad-plated threaded body / Extreme Weather Plating Option Available
- Billet aluminum upper mount
- 5/8" PTFE-lined spherical bearing
- Completely re-buildable
- 2.5" shock diameter to prevent overheating
- Chrome-silicon spring
- 250 PSI nitrogen-charged internal reservoir
- Made in the USA
- Nitro-steel shaft will not chip or rust like chrome shafts
Recommended tire size 285/75R16, wheel 16X8 with 5" back spacing.
_
enunciatechive
