ICON shaft squeak
+1 on the shock boots. Gravel pits the shafts and ruins the seals, even with their "shinguard." I got some universal silicone boots from amazon.
I'm also interested in getting these shock boots before I install the rears.
Do you guys think the fronts need boots? Seems strange that they don't come with them...
Yeah, I defenatly have some sort of squeak coming from my driver side. I did mess with the upper control arm and it sounds like that's what's making the noise. I sprayed WD50 and it got much worse.
Which UCA's are you using? Maybe the ball joints are worn?
[MENTION=78273]Jeremy556[/MENTION],
Can you elaborate on the Shock boots you purchased?
Maybe a link if possible!!! .... lots of shocks don't come with boots and they are definitely worth the additional price up front!
i wish i had known about adding a set of boots to the rears sooner. i have the shin guards, but will be adding some universal boots this spring when i rotate my tires.
These are the ones I got
Fronts don't need boots as they are well protected
Not sure what UVAs are.
If you meant UCAs, no, but I don't see how that would have anything to do with the shock squeaking.
And just to clear this up for anyone worried.... It is not loud. Nothing you could hear inside the truck while driving... It was just a new sound that I had never heard before.
These are the 2.5 non piggy back model, but I'm pretty sure they are the exact same thing as the other ones minus the external res for more oil capacity.
Silly autocorrect. And how do you know exactly that it's coming from the shock? There is a lot of moving parts in there.
But if you don't know how that would have anything to do with it nevermind.
Ordered thanks!
Did you confirm that the sound was coming from the UCA or was it the shaft?
Hm, don't think I complained about a specific noise in this thread, but it is a never ending battle to keep the noises at bay, between the spherical bearings, uniballs, and poly bushings. I keep several types of spray lubricants at all times to mitigate any seriously annoying noises.
sorry quoted the wrong post that was meant for the OP :spy:
Sorry, I did not mean to cause a fuss. It was a noise, nothing major... was just curious if it was common.
I knew it was the shocks because they were the only new part on the front of the truck and I had just washed it.... and the noise started after that. It was a new noise that had never been there before.
It went away when I sprayed some lube on the shaft. Some of the lube may have leaked down to the the lower mount bearing... Really no big deal overall.
I wheeled the truck today and never heard the squeaking noise. The truck performed amazingly well and crawled up things like it has never before.
The LT rear + the ICONs is a game changer off-road. It basically went from a truck that was solid on level 4 trails to being solid on level 5. I know that is a really vague over simplification... but the suspension basically brought the entire system together and the truck actually kicks some butt now. A front and rear bumper + 35s and it would be unstoppable. It's good enough for me (for now).
simple but effective.
IMG_3015_zps620bb851.jpg~original
Do you think those would fit a LT shock. There are no specs given, so not sure how to tell if they would fit...
Can't say about those, but I know the ones I have would (2in shock body). I stuck a zip tie around them at the shock body and the bottom unattached. Even if it didn't provide coverage at full flex, you don't need high speed gravel protection then, anyway.
Thanks, just ordered some, can't go wrong for $12 to avoid a leaking seal down the road. Why they don't include something like that is a bit mind blowing when you think about it. I don't think you need them for the style that have the rod at the top. This is my first set with this orientation.
My lower shock shafts got beat to hell out in Death Valley but don't think I would get boots. I would rather go with the ICON shin guard. But they definitely need some protection when running the desert.
I started with nothing and killed the seals and shafts on my first set in like 12k miles. I got the shin guards for the second set, which lasted longer, but enough rocks struck above the top of the shin guard to kill the seals on the 2nd set, too.
What do you guys think about just the boots and no shin guards. I know my other shocks were pitted up down there, but they were oriented the other way around so it did not matter.... I'm not worried about anything but the shaft itself getting beat up.
I feel comfortable running the boots alone, they are pretty thick, I would think it would stand up to anything my tires might kick up.
Now of you manage to grind a huge bolder up there while crawling.... IMHO it didn't look like the shin guards would help there anyway :D The shin guards might protect the joint at the bottom of the shock shaft some though.
I was thinking I'd make some if necessary but the boots seem to be doing great so far :)
Jhunt
