Icon Stages - Real Life
That's a pretty extreme example. Lots of people are running LR UCAs with Icon, Radflo, and other suspension components with absolutely zero issues (other than some complaints about squeaking, but that's not related to mixing components). You're only going to run into that sort of thing when you really push the envelope of the designed geometry.
Agreed that its an extreme example; although it's always good advise to looking a little more into the combination of mix/match parts because they weren't tested in unison by a manufacturer like a full set of Icon/TC/Radflow/etc parts would. Not saying it would be a bad choice; just a choice that I personally would research more before hitting the "confirm order" button.
Okki
Its true that a suspension lifted vehicle may experience no rubbing issues driving around in normal day to day driving vs. it's unlifted counterpart. Suspension lift with full articulation does not give you any improved tire clearance. When the suspension stuffs, if the tires would rub with no lift, they will rub with lift. That's why everybody trims to fit the larger tire sizes w/o rubbing. Going to 33's will add 1/2" lift to the lowest point over factory tire size. 33 inch tire sizes generally perform worse on the highway in foul weather than factory sized tires.
David
You can fit 33s without rubbing the top of the fender when fully stuffed. The back of the fender may rub when the steering is at full lock but with UCAs you can increase the caster setting to compensate. Adding wheel spacers or wheels with different backspacing causes way more rubbing than going to 33s on the 5th gen in my experience. Highway performance in bad weather is generally more a function of the tire's tread pattern than size.
Upgraded UCA's with more adjustment are not lift. I agree that a lot of fitment issues on a lot of vehicles are due to wheel spacers/backspacing issues.
Off road performance is generally more a function of tire's tread pattern than size.
Works both ways...
David
Works both ways...
David
If you don't mind, could you clarify why you feel that a 33" tires will perform worse in bad weather, and presumably would they be fine in good weather? (as compared to a stock sized tire)
I'm not quite sure I am following you, that's all. I would've figured that tread pattern plays a bigger roll in inclement weather than anything else...
There isn't much difference in performance between 265/70/17 and 285/70/17. Regardless of the application, tread pattern/tire design will play the biggest role in performance. Having said that, some minor differences can be noted.
The larger/wider a tire is in relation to the weight of a vehicle, the more difficulty the tire will have in maintaining contact with the road in inclement weather. The slightly wider, tread pattern will have more tendency to hydroplane and tend to have reduced snow traction. That's not a new theory that I just came up with - pretty widely recognized. That's one of the reasons vehicles on the extreme end of tire size/weight ratios tend to suck so bad in inclement weather. Ever try to drive a late model Corvette in really bad weather?
I am NOT saying that there is a HUGE difference in inclement weather road performance between the two sizes. Given two tires sets, same tire, just a different size, the difference will be minor - but the advantage goes to the smaller sized tire. The difference in performance is akin to the minor difference in performance the larger tire has in offroad performance vs the smaller tire. It's not much difference, but in general the larger tire will perform slightly better in most offroad conditions.
If someone wants to upsize their tires that's their business, I'm not trying to pretend there are major performance problems. I'm just saying it's not all upside going to larger tires.
Sorry I don't have time for more google fu this morning:
Plus-Size Tires | Large Tire Wheels - Consumer Reports
Plus and Minus Sizing Your Tires
David
David
Both articles you linked are about going to larger diameter wheels and lower profile tires (less sidewall). A 285/70/17 has plenty of sidewall which is what you need in snow. That's why on the cars I used to own I ran 17" wheels in the summer (stock size) but went with 16" wheels and tires with more sidewall for the winter. A 285/70/17 Duratrac will outperform a 265/70/17 stock Dunlop in inclement weather - all you need to look at is the difference in siping and tread voids to realize this. My MTRs perform great off road, on dry pavement, and in the rain. They will not perform as well on ice as a Blizzak no matter what the size.
...33 inch tire sizes generally perform worse on the highway in foul weather than factory sized tires.
David
...Off road performance is generally more a function of tire's tread pattern than size.
David
You almost got it except there are several exceptions to that general rule. Here is a thread I did awhile back that explains it a bit. http://www.toyota-4runner.org/5th-gen-t4rs/138094-5th-gen-4runner-tires-ground-pressure.html
David
I understand what you are trying to say, but don't you think you're making a bit too much of a generalization here? Based on your blanket statement, the unsuspecting individual might think that anything taller/wider will perform worse in the rain, which is simply not always true. Tire size does not dictate how a tire will perform as much as the tread pattern will, yet you refuse to accept this and actually try to traverse someone else's suggestions about tread pattern.
Given four sets of tires, two sets (one set of 265/70r17 and another set of 285/70r17) with deep water channeling tread pattern, and two similar sized sets but with wide flat large tread blocks; the tires with the deep water channeling tread pattern will out perform the other ones in the rain no matter the size.
Would you look at that, it does "work both ways..."
I'm pretty sure most of us can sit here all day long making up hypothetical scenarios to disprove people by only telling part of the story, but please for the sake of providing accurate information on a public forum which other people read (and might take as fact), disclose your entire thoughts completely, instead of just the part that alludes to you proving someone else wrong.
Back to edumacating me on the finer points of Icon stages!
I had a member PM me with a layman's explanation of lifts/suspension mods, which I really appreciated!
What else would you like? Your questions have been answered in this thread and there are 100's of threads out there with the same info. If you have other specific questions speak up!
I'm sure you have been to Icon's site and they lay out pretty much everything included in the kits. Have you done much offroading?
I'm just messing with you guys - carry on.
Like I said, a member PMed me with some basic info. In the meantime I looked through the Off Roading Tips thread in the general section of T4R, and am starting to think my meager funds would be better spent initially on recovery equipment. I have nothing save for the crappy jack that comes from the factory and a hastily put together emergency kit.
Maybe I should have started a thread asking for advice on the priorities for off roading instead of jumping right to Icon Stages.
:doh:
Good idea. Even lifted trucks with big tires get stuck so you want to have recovery equipment in the truck any time you go off road.
So, BudBuilt hidden winch mount + some sort of winch a good start?
Are the factory recovery points sufficient?
High-lift jack?
Except you are pretty much going to need new suspension with the winch, even with synthetic line.
They work good enough. Still need shackles, snatch strap, etc.
Yes, with the adapter to allow you to lift directly from a wheel. That is about all you will be able to do with it until you have sliders, at least.
Quote:
<table border="0" cellpadding="6" cellspacing="0" width="100%"> <tbody><tr> <td class="alt2" style="border:1px inset"> Originally Posted by eddiebx
</td> </tr> </tbody></table>
It wasn't a blanket statement it was a generalization. That means all else being equal..., in this case yes a wider taller tire will perform worse ON ROAD in rain, ice, snow than the exact same tread pattern in a slightly narrower, shorter tire (tires sizes given, vehicle given). I'm not trying to traverse someone else's suggestion (I don't even know what that means). I'm saying that going to a larger wider tire of the exact same, type and brand as the smaller size will give slightly degraded performance on road in foul weather.
I agree with that 100%. I never suggested comparing a larger MT tire to a smaller tire specifically designed for xxxx (fill in the blank). I'm suggesting comparing the exact same brand and tire in different sizes. If you look closely at what I posted, I didn't say the stock tire is better in the rain than your larger 285/70R17 size, I said the stock size - as in the stock size in the exact same tire, no difference except size.
You seem to be reading intent on my part where there is none. My two Tacomas ride on Micky Thompson ATZ's in 265/75R16 and 265/70R17 respectively for the OR and Sport. I have been very pleased with their performance they handle on road, on road foul weather and off road chores very well (much as you describe your satisfaction with your tires).
I am about to purchase a set of tires for my wife's <acronym title="Toyota 4Runner">T4R</acronym>, I will be purchasing Micky Thompson ATZ's. Will I purchase the 285/70R17 or 265/70R17? The tire brand, type has been decided, only question is the size. Everyone acknowledges that the larger tire will degrade gas mileage in comparison to the smaller size, many believe it is worth it for the slight increase in performance off road vs the smaller size. My point was that the gas mileage decrease is not the only negative to the larger tire - there is a slight decrease in on road foul weather performance. The larger tire is not much different in performance on road than the smaller tire, just as there is not much difference in the slight increase in off road performance vs the smaller tire.
That's what I meant by it works both ways....
From the above links:
Why Downsize?
For the most part, downsizing is great for that second set of winter tires. Snow tires tend to become much more expensive at sizes larger than 17”. In addition, the narrower the tire, the more effective it tends to be on snow and ice. So if you have 18” or 19” wheels and want an extra set of wheels for snow tires, it’s often a good idea to go down to 17” or 16” wheels for the winter set, which will give you better winter performance at a lower price.
If you look at the other links and go down to the graphs at the bottom you can see a direct comparison of the plus sized tires in hydroplaning performance. This difference is primarily due to the increased width, not due to the decreased sidewall. I understand this is not the clearest example to look at, as I said before I was running short on time this morning and didn't have much time for google fu.
Greg,
I haven't had a chance to review your link yet, I will.
Thanks,
David
I have Shrocworks sliders which are bolt-on. Does that make a difference, vs. weld-on, I mean?
Are you saying that the weight of the winch necessitates stiffer suspension? Seriously, you have to spell things out for me, I'm a total greenhorn.:noidea:
The bolt on sliders will work fine as a jack point - however, it is very tippy. Make sure to chock the other tires, keep your head out of the arc of the handle (especially when lowering), and put a blanket between the bar of the jack and your door. I usually only jack from the sliders to change a tire.
The wheel adapter is great because you will primarily be using the jack to lift a wheel to stack rocks/logs under. By lifting from the wheel you don't have to overcome your suspension down travel, and you don't have to lift as high, which helps with stability.
Yes, the weight of the winch and mounting plate will really take a toll on handling, especially because it is so far out in front of the vehicle. With my icon coilovers, which have a much higher spring rate than stock, I think I lost about an inch of lift when putting on a winch with synthetic line.
Bolt-on are fine. Some debate about which are superior, but both bolt-on and weld-on sliders have a proven track history.
Yes, winch weigh will necessitate stiffer suspension.
David
BillM777
