icon sway bar relocation brackets - help
soundstudio315
The new block doesn't line up with the factory holes?
The instructions say to use the factory hardward and in the recessed holes on the bracket which are towards the rear of the bracket. There are new threaded holes for the factory U clamp to bolted on to it.
Again the new block recessed/count bored holes don't line up with the factory holes? And Icon sends you allen head bolts for for the counter bored holes?
Any ideas?
Putting one of the new bolts in the rearmost countersunk hole (the hole closest to one end) of the spacer and into the rear hole in the frame and hand tighten. Now the other counter sunk hole does not line up with the forward hole in the frame ?
If that is the case then you either received mis-drilled spacers or a set for a different vehicle.
Yes that is case, argh, so frustrating. Guess i'll be call Wheelers in the morning.
johnnya
