ICS FAB Beefy Dash Mount for 4Runner
Mine with that t9 headunit.
Pretty solid
Love mine and it doesn't block the AMD aka Accessory Meter Display :thumb:
It was an easy choice for me and I have no regrets. I’m a neat freak and I love how it looks like it was meant to be there. A quality product that was super easy to install.
Pretty solid
With your emergency glass breaker tool on the right by your leg, and mounted to the center console - does that bother you at all? I have contemplated mounting my CB (Uniden 520xl) down there, but have thought it would hit my leg and be annoying.
Any regrets with putting that tool down there?
It doesn't really bother me. I Forget that it is there.
I have it in a pretty secure pouch and thought it was the safest place to access in a emergency but also safely secured if i'm involved in an accident.
That CB might fight pretty nice there , they are pretty thin, But it all depends on you.
I am very happy with this product.
Hey macscac, like your ram mount setup. Can you please show what parts you used for that setup? Part numbers, and where you purchased yours would be helpful info too. The pictures you posted don't quite show your setup. They have RAM Mounts on Amazon just not sure if its the actual vendor selling there.
My ICS Fab mount is on its way!
Amazon.com: RAM Composite Double Socket Arm: Electronics
Amazon.com: RAM Ball Adapter with 1/4"-20 Threaded Hole
Amazon.com: RAM X-Grip Universal Phone Holder with Ball
Can you put up a pic of how you were originally planning to mount your CB?
I have a Uniden 520xl which I have been trying to figure how to mount it on the top middle part of the dash....I think this would do the trick. Ideally I'd use this mounting plate to form a front that I could fab up another shelf off the back of (based upon your "this sits too high" comment), and mount it to the top of the dash. Would have to figure how to hide wires, but obviously just brainstorming right now.
honestly, I did not mount it up there..
I did not want to deal with hiding the wires but mostly, I did not want a big brick up there. it would bug me.
I ended up buying a diff CB and mounted it in my center console.
I use this dash tray for my phone x-grip(s) and my fmrs handheld radio
I finally stumbled around to installing the ICS FAB mount today. I put it off because I had other mods that I wanted to do while I had the console/dash yanked out. I'm still impressed.
This flat and sturdy shelf, easily accepted all of my accessories.
One thing to note... the 9/64" drill size (that ICS recommends on their youtube install guide) isn't large enough to fit the supplied-screws through.
DEMIK, how do you have your iPad mounted low on the passenger side of the center console? Can you post some pics of it? Are you going to move your iPad to the ICS Fab Top Console mount? Thanks.
Hey, there is not a clear shot of it, but it looks like you mounted the Ram Mount inverted with the ball underneath the bracket. I am surprised there is room for that, but I like that it gets the mount lower. What type of ball mount are you using? Has this worked out well?
[not the person who you quoted]
There is plenty of room underneath it. Amazon does not have a very good selection of the mounts so I'd suggest checking out ebay. Also I wasn't a very big fan of the power taps for the USB, personally I'd have a better T type tap on hand, I know wago usually makes good stuff.
I might be able to take pics if there is something really specific. For me, I haven't found the best mounting methods just yet but then again I hardly drive anymore. I might try to rig the ball mount through the ICS log on the drivers side and use the short 2 ball mount for my phone. Blocking the vent is a no go for me being here in AZ.
Also I have a go pro mounted to the top of it
I'm curious as well on a 2020. I bought one but when i fit it up, there is a pretty decent gap on the sides. Seems like you will see the bolts that go into the sides since the bezel is slightly rounded.
I have one on my 2020 ORP. Works fantastic. Have two Ram ball mounts on it for my phone and a stand-alone GPS unit using the X grip device holders. Will try to take pics and post tomorrow.
AndiGarage
