ICS FAB Beefy Dash Mount for 4Runner
I have one on my 2020 ORP. Works fantastic. Have two Ram ball mounts on it for my phone and a stand-alone GPS unit using the X grip device holders. Will try to take pics and post tomorrow.
Yes, please get some pics so I can see if your gap is like mine.... that sounds bad.
I'm curious as well on a 2020. I bought one but when i fit it up, there is a pretty decent gap on the sides. Seems like you will see the bolts that go into the sides since the bezel is slightly rounded.
Here's my 2021.
Quick Take - 4Runner Phone and Tablet Mounts by Tackform - 4X Overland Adventures
I like these Tackform mounts much better than my old Ram mounts. Lower profile and more adjustable. Although Ram now sells one with a split arm as well. X-Grip from Ram interferes with the device buttons as well. I still have one short RAM mount on the passenger side for my InReach mini.
Thanks for the pic! Is there a decent gap between the mount and the bezel?
I don't think so. I can check next time I go out to my 4Runner. I certainly don't notice anything. Mine was a PIA to put back in on the left side for some reason.
That was never an issue on my FJ and I had removed the similar bezel many times. It makes me hesitant to pull the 4Runner one again but I probably don't have a need to do so.
Looks like it's blocking a good portion of your view.
You are right, the picture does look that way. However, that is not the case. Just a bad pic on my part. I'm 6'3" tall so I look right over the devices that are mounted. It would be easy enough to reposition them however, with the RAM ball mounts. The only time it has gotten in the way was when I crested a steep hill offroad and was trying to look below the hoodline as the road dropped off sharply.
Im thinking about picking one of these up. However I am a little leery about drilling into the plastic. I thought Id pick up a replacement bezel incase I ever want to get rid of it. Does anyone have the toyota part number for it? Everything I see shows it as part of the radio assembly and it cannot be purchased separately.
I think this mount is great, but if you want a "no drill" option, look at Alpha Foxtrot Design.
PRWhite
