Ideas for rear suspension?
StupidMuphin
So it has come to my attention that I now have enough funds to swap out my rear suspension on my 99. The front has a super nice adjustable coilover on it and I was think of with I couldget to match the rear. I was thinking OME 891 coils with Fox 2.0 shocks. Does anyone have experience with these shocks?
891's bring the suck all day! As Toytec will tell you, unless you're carrying more weight the ride isn't going to be good. Then, after carrying more weight you'll notice the rear is sagging quite a bit. Next, you're stuck sagging springs and will need to get new ones. Ask me how I know this. Of this is just my opinion after dealing with it.
No experience with them yet, but my plan is to go with the Sonoran Steel kit using Radflo 2.5's front & rear. One day :moping:
Sounds expensive. What do you have on now
Stock
and what don't you like about it?
It's stock
On my taco I have fox 2.0 shocks up front and Bilstein 5150's in the rear. It works fine, but the front 2.0's seemed to fade quickly.
Any coils you would recommend then? Another option I considered was the SuperFlex coils. And experience with those?
This is my opinion on rear shocks, if you want to talk front, then there are more things to consider...
Fox makes great shocks, but it's all about intended use! If you are loaded down or doing a lot of fast driving I wouldn't get anything less than a 2.5" shock. If you mall crawl and hit the occasional trail or go camping but don't over load the thing than a 2.0" shock will do the business.
Remember when you buy a nicer shock like a Fox/King etc in a 2.0" size you aren't getting a better shock than say a Bilstien 2.0" 5100 shock. But you are paying a lot more money for it. Now the money isn't wasted, what you are buying is a fully rebuildable, fully adjustable shock that you can tailor in a million different ways to fit your needs. You can change compression and re-bound valving, you can change the PSI of the nitrogen, things like that. If you are looking for something that has those features, then getting a 2.0" Fox/King is the way to go. But if you want a nice bolt on 2.0" shock that you are just going to use like 95% of people do, I wouldn't waste the money.
Reservoirs are another discussion and can help bridge the gap if you are a moderate user, but don't have the funds to spend on a larger 2.5" shock. The pure advantage of the 2.5" shock is you have a lot more shock oil in the shock, which allows the shock to stay cool and work better for longer. Once the oil gets hot, the shock fades and the valving doesn't work like it should. a reservoir will give you the added oil capacity and cooling without buying the larger shock. This could be a reason to get a Fox/King type shock, or you could buy something like Bilstein makes that has a small reservoir but isn't rebuildable.
Also keep in mind Fox does not make a bolt on shock for 3rd Gens that I know of (may be wrong here).
What are your plans for use? This will help answer a lot of the questions!!!!
Man I installed a used set of LC 7 wraps and some Monroe shocks made for a '94 LC. Cost me $150 total and the ride is smooth as butter. I've carried heavy loads for a bit, sagged a tiny bit but nothing bad. DD is great, floats over potholes and bumps in the road.
If nothing else, spend a little money now, if you don't like it, then spend the big bucks.
Rialm
