Idler pulley replaced at 65,000
delloro
First part failure so far, except battery died a bit prematurely.
Not the bottom idler, but the one closer to the steering pump. Noticed an intermittent whirring sound.
O'Reilly showed all 3 parts being the same replacement part. Only one came with the required bushing, and the bottom pulley was different.
Just an FYI.
I had 2 pulleys and idler arm replaced under Toyota Platinum Warranty at about 70K. Good luck if you are repairing yourself.
Thanks for the update on the O'Reilly parts, helpful info.
For what it's worth, I had to replace the idler pulley on my JK around 30k miles hah.
Yes. I believe the below info is correct.
2 - number 2's 16604-0P011
1 - Number 1. 16603-0P030
And the Toyota Parts link: WATER PUMP. Toyota | Toyota
331627d1555203481-idler-part-numbers-ae2f7fb4-c56a-4453-9f96-969e78f0e7c0-jpg
H.Sikina
