Ignition Coil - OEM or Aftermarket
nicheel8
Member
I need a new Ignition Coil. Would you guys go Genuine Toyota or Aftermarket? Also, should I replace all 3?
Local dealership has them for $75.00
This OEM Denso 673-1201 coil is identical for $58 on Amazon. I would ONLY use Toyota or Denso (Denso is Toyota subsidiary that made them in the first place.) A Chinese knockoff in such a mission-critical application does not warm my heart. It would work, but for how long? I would replace only the bad one. The vast majority of these will outlive the engine they are in.
http://www.amazon.com/Denso-6731201-673-1201-Ignition-Coil/dp/B002Y39NFY
Now, if you had an Audi, I'd say swap them all and keep a full reserve stock on hand. (GF's A4 drives me nuts....)
lilliagarcia
