Have you tried to tighten the core thats in there now?
Gave that a shot. I guess I'll try to take it all the way out and then reinstall. We'll see!
TPMS is just doin' it's job buddy.![]()
As usual with the temps dropping the light on the dash went on. As usual, it was the spare. I filled the tire but still heard a very faint hiss. After 5 days the light is on again. Should I try to replace the core as I guess the entire TPMS valve is expensive?
U can go to a tire store and they'll just give you a new valve core. we have hundreds and throw many away where I work. If its the actual nut that holds the sensor in place thats leaking the tpms kits go for about 5 bucks.
I too dislike the tpms system. Its for those that are too lazy to even glance at thier tires before they hop in their car or are to lazy to check the pressure once a month.
Tire shops will check all your pressure for free (or at least my work does), the least you can do is drop by the local shop and ask to get your pressure set
went to a local shop and they lower the spare tire and they put it upside down for easy fill up of air, good idea???:wtf:
Checking your tire pressure once a month is fine. How about when your driving down the road, get a nail in the tire and two miles later you have a flat tire? It takes a 1/4 mile to 1/2 mile to pull over on the freeway, at that point you have ruined the tire (hence $150.00 to $250.00-maybe this is why tire people don't like TPMS). This is where the TPMS shines. It lets you know you have a problem.
It's my experience that most tire techs do not like the TPMS because they have to be CAREFUL when dealing with the tires/rims.
