Inclinometer Questions
I am new to this. Do you happen to have a link that shows how to bolt it to the dash? Or how to take the dash apart without destroying the vehicle? Thank you
You will most likely destroy the right/passenger vent register to get to that corner bolt on the dash. Might as well check on eBay now. Note that the vents in the dash pad vary based on whether you have an early/long tray dash with a wrap around corner vent, or whether you have a late/short tray dash with a rectangular corner vent.
The inclinometer cover also varies based on the two dash types.
After taking my dash out and breaking the vent, I just didn't put that bolt back in when I reassembled the dash.
The factory plug is taped up behind the radio and ash tray.
My inclinometer has the pigtail plug cut off so I can't see what it is supposed to plug into. Do you happen to have a pic of the plug that is taped behind the radio? Is is male or female? I have 2 plugs that I can see when I remove the glove box and neither goes to anything.
D'Angelo
