Incoming!
ajwhitt44
Just got this pic texted to me from my wheel guy! Only had the car for 2 weeks but I can't keep anything stock!
EDIT: Wheels mounted up!!
Only slight modifications were needed - no mudflap cutting necessary. The front fender liners had to be moved slightly forward, but otherwise they fit great!
Rear
Front
I'll have a full writeup and better pictures after the weekend probably!
Nice. when are you going to have them installed? I'm contemplating duratracs with my new wheels that arrive Monday.
hey! They are 265/70/17s
Also installing bilsteins in the front and daystar 1.5 in the rear so the tires fit in there nicely!
We all want to know!! where are you setting the Billies at? What all do you have? Do you have FJ springs or others? Info info info
Truck is at the shop now, it'll be there over the weekend and into next week, as I'm going to have the chrome bits painted to match the body also.
Haha you just got all the info. Stock springs for now (I was told they'd work just fine with the bilsten shocks and the rear lift kit), Bilsteins are going to 1.75 or 2.5, whichever levels the truck.
I'm going for a subtle, clean look...don't want the truck jacked to the sky! The only reason I'm even doing a lift at all is because I wanted to fit bigger tires!
Sounds like a great plan. If your doing the 1.5 in rear, you will prob have them set at 2.5 level. Look forward to seeing it.
Thanks man! [MENTION=91232]jakeryan[/MENTION] recently did this setup and it just reinforced that it's exactly what I'm looking for.
His ride is damn near exactly what I am trying to achieve....subtle yet has a great presence.
Basically what I have as well. I have FJ springs all around with a net 2" lift budget boost spacer in the front with 1.5 in rear.. I have some uninstalled Billies waiting! trying to decide how I want the setup to run at this point, just billies on 2.5 or billies on .85 with the budget boost spacer. Now after many miles and settling, the back is 2" higher than front, i would like to bring that together a little bit.
DionicioLives
