Install help piaa lights
Coopsdaddy
I am getting my 4xinnovations bumper this week and want to run piaa 510s in bumper,i belive i read you can just wire up lights and run right off stock headlight switch,just cut and sllice and bolt in?
Whats the best looking incab switch for running two piaa 520atp on too of bumper?
OEM:
Sorry about the big pic.
https://smile.amazon.com/gp/product/B00KTKFBG4/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
foglite-jpg.488167
Use a relay, don't put all those amps through the switch, any switch.
You want power for the fogs direct from the battery (with an in-line fuse) or fuse box. You tap the relay coil/switch power depending on what behavior you want from the lights (always available = direct to batt, key on only = key on source, with parking lights, with lows, etc. N.B. Headlight circuits are switched hots with DRLs, switched ground without. I do mine to parking lights.)
Tx470
