Install/review of an Atoto wireless Carplay & Android Auto unit
Disclaimer: I paid for everything, this isn't a promotional review, etc. etc. I own a 2008 4Runner Limited with JBL/non-nav
I wanted a name brand unit but due to the chip shortage, I gave up waiting for more budget wireless Carplay and Android Auto options. I bought this Atoto F7 Pro XE even though it had no reviews. I figured their other options were generally reviewed well and this seemed identical to previous models except that it added the wireless connection. It was $250~ after coupon at the time of this review.
Amazon.com: ATOTO F7 XE 10.1 Inch Double Din in-Dash Navigation with Bluetooth, Wireless CarPlay & Android Auto, QLED Display, Mirror Link, HD Rearview Input, Quick Charge, USB/SD(Up to 2TB Storage) F7G211XE : Electronics
The other two items I purchased are as follows:
  • Metra TYTO-01 -- this is to retain the factory JBL amp
  • Metra 70-8114 -- this is so that I don't have to cut into the factory harness, more on that later
The TYTO was about $50 and the second, optional harness was only $9 (seems like a no brainer to me).
The first thing I did when I received my radio was to wire the TYTO harness to the ATOTO radio harness. I recommend you do this inside your house or in your garage workspace. I actually did it at my desk with this Youtube video playing -- skip to 4:45 to see him wiring the TYTO to his aftermarket radio harness. I used the same method as he did to join the wires -- using crimp connector caps. Use whatever method you are comfortable with, but as a beginner, the crimps were very easy to use. Also worth noting that ALL of my harnesses came pre-stripped at the ends. NOTE: don't crimp the black ATOTO ground wire to the two TYTO ground wires yet -- you're going to add another ground to these three. Be sure to read the instructions on the TYTO harness to make sure you're connecting to the correct ATOTO wires -- the ATOTO wires were all clearly labeled. The easy one to mix up is the blue ones -- make sure you are connecting the amp correctly etc.
Once you've got everything wired up as above, you should be left with roughly 4 wires -- two SWC wires, a parking brake wire, and a rear camera wire. You will now have to wire the Metra 70-8114 harness (aka Metra SWC harness) to the ATOTO radio harness. There are two wires of note coming out of the ATOTO radio harness -- "steering wheel key#+" and "steering wheel key+". Taking the Metra SWC harness , you will snip off the end with the black molex along with the AUX cord. You can discard this. You will then wire the steering wheel key+ wire from ATOTO to the black/green wire out of this Metra SWC harness. See pic below:
Next, you'll wire the steering wheel key#+ to the green/brown wire out of the Metra SWC harness.
The last wire you need to connect on this Metra SWC harness is that ground wire I talked about earlier -- it should be coming out of the Metra SWC harness and I snipped it back, then tied that into the black grounds for the ATOTO harness (1) and the TYTO harness (2) for a total of 4 grounds wired together. I hope this part is correct -- if anyone with car AV experience wants to chime in and tell me I did it wrong, please do so!!
Note for clarity: you can see the TYTO box in the background of these two above pics. You are not wiring into this harness for the SWC controls though, so ignore it.
The white end of this Metra SWC harness will plug right into the 20-pin white molex connector coming out of your 4Runner -- it should be easy to spot because it only has 6 wires into it. PS-- if you connect the red & white RCA cables from the Metra SWC harness into the back of your ATOTO or similar head unit, you should in theory retain AUX input from your center console. I forgot to test this but I assume it's working. See pic below of the 20-pin out of the 4Runner on the far right. The molex connector on the left is where you'll plug the main TYTO harness.
This should be all of the splicing/harnessing you need to do. From here, you should be able to 1) plug the Metra TYTO harness into the big Toyota harness, 2) plug the Metra SWC harness into the 20-pin Toyota harness, 3) plug the Toyota antenna into the back of your ATOTO radio and also plug the other end of the Metra TYTO into the back of your ATOTO radio and then plug in any peripheral devices into the ATOTO (Wifi antenna, 4G, USBs, rear camera, etc.)
I am realizing I forgot to take finished pictures. I will do so ASAP and update this thread today or tomorrow. It looks great and wireless Android Auto/Carplay both work flawlessly. I also tested the provided phone link USB cable and that works too. I did not use the Metra double-din kit for this installation. Since it's a floating 10.1" screen, it doesn't need it. In fact, this model of 10.1" screen is nearly a flush mount, so you can't even see behind it to notice it's missing the DIN kit -- this is a blessing and a curse, because it leaves you with very little room to adjust.
I'll continue to update this thread with more revisions based on questions and my thoughts on the radio long-term! So far, for about $350 all-in, I'm thrilled and I'm also glad I took on the project.
Yea - the installed photos really help. How does it work for you?
I'm liking it so far but I haven't really driven much since installing it. I'll try to provide a more detailed review in the next couple of weeks
I will only use it with carplay/AA and that part has worked flawlessly so far... No disconnects etc.
So from your normal driving position, can you still see the factory clock and range/mpg info? Looks like it's almost fully obscured in the pics. Are the HVAC vents blocked much?
Sent from my moto g stylus 5G using Tapatalk
HVAC isn't blocked at all. I'm 5'11 and from my normal driving position, I can only see the bottom half of the factory clock/range info. I definitely want to figure out a way to adjust the radio upwards by half an inch or so, maybe a bit more.
I used the factory DIN mounts so maybe if I use their supplied ones, I would be able to adjust it upwards more. I've got a baby home sick from daycare so unfortunately I don't have any time to tinker with it at the moment!
I have already thanked the OP in a PM but felt I needed to do it again. I had some questions before I pulled the trigger on the Atoto S8 Ultra head unit. He not only answered each question but also started this update thread with the wiring pics. I'm not interested in the 10" model for a few reasons so I'm going with the 7" Ultra that looks like a regular head unit with nothing sticking out from the dash. I have purchased several Kenwood Double Din's over my many years and not one made it past the 1 year without having issues that continued to get worse and they were all removed before the 3 year mark. Not saying the new ones are like this, I hope they would have perfected these by now. Pioneer is the one that has been in my F350 Fat Bottom for over 10 years and has never had a single issue. As the OP stated, most of their Head Units have been out of stock for awhile now. Plus to get a Pioneer that even comes close to the Ultra is well over $1300 and those days are behind me. I usually only purchase well known brands with a history of working well on major items like this. Because of the info he provided and the others on the forum that have mentioned Atoto I am going to place the order this weekend. I will take pics of the install and final result so hopefully it can help someone else down the line. That's what I love about Forums like this one. Didn't mean to write a novel, y'all have a great day/night and God Bless from the foothills of the Blue Ridge Mtns!!!!
NCH
That 10" screen is not for urban areas, I think; it's just asking for trouble.
I agree, if I lived in the city and parked on the street I'd definitely be paranoid. Luckily I'm in the 'burbs and park in a garage. Doesn't get driven much except for roadtrips or quick errands around town since I'm WFH.
But yeah, if you park on the street, I think I'd avoid a big screen like this -- a lot more noticeable, and probably a lot easier to remove than a regular double DIN.
Huge props for original post. Saved me a ton of time wiring this up. Follewed to the T and it all worked. The only down side is it covers up the outside temp about half way.
Im still messing with the EQ, not getting the same amount of bass out of the factory subwoofer as i was with the factory headunit. Going to try to adjust the TYTO interface module to see if that helps.
So far this headunit has been great esp for the price. Bought it for $180 with a $20 coupon on amazon 2 weeks ago.
1+ year update: it's still going strong and actually seems to connect faster to wireless Android Auto these days. It also works flawlessly with my wife's iPhone/Carplay wireless
One gripe is that sometimes if you turn the car off completely and then restart it a minute or two later, it struggles to wirelessly connect to my phone. I.e. if I'm at the gas station, turn the car off to gas up, when I turn it back on it won't auto-connect and I have to fight it by reconnecting Bluetooth/wifi etc.
Were you able to use the factory reverse camera with the new head unit, or did you have voltage stepdown issues?
I don't have a factory reverse camera. I want to add one eventually but it isn't a high priority haha
Did you ever find a way to shift it up a bit?
How's this unit working out? I'm looking at a 9" version S8 for my 04 w/JBL and RDS - I think it would be a similar setup as yours.
still going strong! I figure eventually I'll have to replace it, but there's zero lag or anything. the random wireless disconnects still happen, but if I'm plugged it that never happens -- and they're infrequent enough that it doesn't really bother me when I'm using it wireless. I have never tried to update firmware which would likely fix it.
No, I never actually tried tbh. I miss being able to see mpg/temperature info but I calculate mpg by hand anyway and I can see the temp on my phone which gets me close enough.
If I was doing it over, I think I'd aim for a model that you can adjust the screen up or down slightly.
Blue/pink connector
I see in your photo that the blue/pink wire is connected somewhere, I can’t find anywhere on metra what that wire is for; what do you have it connected to? When I hook up my speaker using all these steps, I still can’t get sound to my rear speakers or my steering wheel controls to work. I have the F7WE Atoto head unit. 2003 Limited 4Runner with V8.
do you have the JBL setup?
I believe the blue hooks up to the power antenna and the pink hooks up to the rear camera (which I don't have, I just connected them anyway).
did you go into your Atoto settings and map your keys for the SWC? let me know if you need help with that and I can elaborate.
