b407driver
lol, come on man. it's only a 4 page thread. read it.
edit: classic, it's now a 5 page thread.
I have my settings set to 40 posts/page in my user preferences; it's only a 2-page thread to me.
I have the rola on oem crossbars - it's really quick on/off - it can be a bit awkward but it's manageable to put on or take off by yourself if you're careful. I also marked my crossbars with a subtle line using a sharpie so I can quickly align the feet that attach to them because I am OCD about the thing being perfectly centered and aligned which is what takes the most time.
No wind noise for me (using the rola wind fairing as well) but a loss of about 1mpg.
Wow a whole mile. That seems like a lot to me. Anyone else see similar results?
Here are a few pics with the extension, I mounted about as low as you could on the factory rails. It is loud at highway speeds with nothing in it, sounds like a plane flying directly overhead. Quieter with a couple of dog cages wrapped in a tarp on our trip to the outer banks. I keep it off the truck unless I need it.![]()
Sent from my SM-G950U using Tapatalk
Here's a few.
never ran it without the extension so I couldn't tell you.Thanks bro that looks great. Do you think it's so loud due to it being closer to the front of the roof? Have you run the rack without the extension before? If so, do you notice the difference? Ive had mine with and without cargo up there on the standard size and it isn't much louder than when I don't have the rack up there.
Thanks! Do you notice lots of wind noise with the rack and extension? Ever had it without the extension? I can hardly tell the difference bt having the rack or not without the extension.
Yeah, I can hear it. It got louder with the extension, I had some vibration that I really couldn't explain. I'm thinking something is loose somewhere but haven't tracked it down. At highway speed it would make humming sound that I can only think of as some harmonic vibration. I put a ratchet strap on it and it went away but that's not a permanent solution. So until I figure it out I added this aluminum angle that also stops the noise and is spaced so they hold my cases to the outside of the rack.
I think the noise comes from the amount of overhang in the front. With the factory rails spread out as far as they will go the mount is still on the first rails of the front section of the rack.
Without an extension, mine had the harmonic vibration (that's precisely what it is) between 60 and 75 mph; you could put your hand on the headliner and feel it, and the sound would increase/decrease with speed, but not linearly (i.e. once you slow quickly, the vibration slowly quiets to nothing). Drove me nuts for the first week, during which I finally tried mounting a load, and the vibration immediately went away.
Now that I have two Rotopax plates permanently installed, the vibration no longer occurs. Prior to that, I had used a bungee cord threaded in and out of the center of the bottom tubes across the center to break up the harmonic, worked great.
Just get a black one and no one will likely ever ask what it's there for.
Makes me think the low pro mounts noted in this thread would be a more secure system for off road travel with this rack.
They are indeed bombproof. Four days on the White Rim with a pretty decent load (100+ lbs), rock solid. Those crossbar mounts it came with looked rinky-dink out of the box, but not sur e what you can expect for $130. I'm happy spending the $75 on the low-profile mounts.
Big daddy - interesting about the Rola mounts shifting/loosening from I presume off road driving.
This guy seems to mention a similar issue but his rack was loaded well over Rola's stated weight capacity. http://www.toyota-4runner.org/3rd-gen-t4rs/180623-rola-roof-rack-review-under-heavy-load.html
How much weight was in your rack when it began rattling?
OP, have your low profile brackets come loose at all? Did you use loctite? Also, what was your method of rust prevention for the brackets since they came bare steel? Mine had rust on day 1. Had to take them off, sand off the rust, rust reformer, and paint. Hoping that keeps the rust away.
