Installed the Magnaflow Side Exit Exhaust on my 2014 Sr5
I just installed this on my '16 TRD Pro. It ended up taking me 3 hours because of a few minor but time-consuming problems.
Here's a heads up to anyone looking to do this install:
1. Get a stubby ratchet and/or angled or offset wrench! Even though my T4R is only 5-months old, I had to use PB Blaster on the two bolts in front of the factory muffler. It's difficult to get a full size wrench or ratchet to these bolts because they are positioned above the pipe and crowded by the sway bar, vehicle frame, some cables, and other obstructions. I could barely squeeze my hands up there. I ended up drenching the bolts with PB Blaster and then using a stubby ratchet and tapping it about 50 times with a crescent wrench to get it moving. (Hammer wouldn't fit.)
2. Jack up the rear end a few extra inches! I had the rear end up on jack stands (by the axle tubes) so that the rear tires were about 2-3 inches off the ground. Even so, when it came time to pull out the factory tailpipe, I couldn't maneuver the damn thing out because the back end of the tailpipe would hit the ground as I twisted it to clear the rear axle. I ended up lowering the spare tire and also unbolting a heat shield in order to maneuver the factory tailpipe out.
3. Lube the hangers and rubber isolators! I had to spray silicone onto the rubber isolators and the hangar hooks. Then I used a large pair of adjustable pliers to press out the hooks from the rubber isolators. I tried just using my hands and it was not a good scene.
Also, you'll need a deep socket 15mm to install the new clamps.
Now that yall have had the Magnaflow on for a while and its fully burnt, how is it? Does it drone at all? Still loving it? Any regrets?
Curious too.. had to wait in traffic the other day and had the dogs in the back with the window down and got all scared about CO coming in. It does seem odd that it's not side exit from factory
charlesz
