Installing lift help...
4RunnerKyle
Trying to install my Toytec Ultimate today.... Looked in the master directory and I couldn't seem to find, or may have overlooked..... What are the torque specs for the upper control arm to frame in the front and. The rear control arms mounts.. Frame and axle side in the rear... Trying to make this as painless as possible with limited tools
Any help would be appreciated
Kyle
Just looked it up in the FSM for you. 64 ft lbs on both rear UCA bolts. 107 ft lbs on both rear LCA bolts.
Edit: Looks like front UCA to frame bolts are 87 ft lbs.
Awesome diagram..... Was only able to get the back done today... 890s.... Planning on tackling the front tomorrow.....
One thing I noticed though... The three top studs in the coil overs are loose... Should I tighten them down and loctite them in before installing them...I can move them with my fingers
Yea they should be far from that loose, you shouldn't need locktite if you torque them to spec though it wouldn't hurt (at least on the inner nut since you can't get much leverage on it).
goddesszilla
