Yeah I know, the only time I had time, it's was raining too much. Tomorrow should be sunny and I have some free time too.PS, I am still waiting on some pictures.![]()
Middle mount:
Rear mount:
I did my install in 45 min with one person. I'm not gonna lie I was terrified of kinking the kdss lines, it's not easy to pull the lines away from the frame.
I ended up loosely bolting the front mount, then used my car jack on the rear of the slider to slowly lift the slider into place. I used my free hand to pull the kdss lines away from the frame. Easy as pie!
Cool thanks for the extra info. I didn't realize you had to really pull the KDSS lines away from the frame. Is there a decent amount of tension? I think someone said they had to bend the supports. Did they have to bend the supports b/c of the tension?
Middle mount:
Rear mount:
Thanks! These are great! Are there three mount points? I thought there were two.
Nice! Thank you [MENTION=111795]GabrielM[/MENTION]! Looks like they don't even go behind the KDSS lines in your pictures. Just above and below. Would that be a correct statement?
I just finished installing the Schrockworks sliders on my '14 TEP. Wasn't that bad, took me about 2 hours total, working by myself.
Gotta' say the tips and tricks posted here helped a ton, as I knew what to expect.
After reading about all the potential issues when you remove the strap for the gas tank, I ran my fuel down as recommended until the light came up (ended up still having 4 gallons in the tank). Then I placed a socket on top of my floor jack, and gently inserted it into the hole in the skid plate right next to the strap you're removing. I only lifted it enough to contact the gas tank. That way when I removed the strap I had effectively pinned the tank into position, so the strap didn't move.
Sorry the pix don't line up with the text, it's my first post with pix and I don't know how to attach them at a specific point.
Couple of things that will help you on the install - use the box they ship the sliders in to support them during the install. I added a couple of 2x4's on each end and it positioned the sliders almost perfectly (meaning the holes lined up nicely)!
I used the trick posted earlier and used some shims to push the KDSS lines away from the frame, that allowed the slider to slide right in behind them against the frame.
Really wasn't as bad as I expected. Turned out nice, I'm very happy with these.
Looks great. Mine should be here in the next day or so. This is a super helpful thread. Pretty excited to get my hands on these, it's been awhile. The quality looks like it will be worth the wait. Pics to come.
Took the plunge and ordered them! Now I just have to wait...![]()
