interior lighting
blairvt
I've seen where guys have installed some kind of interior lighting that lights the back up like daylight, but no directions on how to do it. Anyone got a link to show me how to do it?
Easiest/cheapest way is to replace interior incadesent bulbs with LED type - check ebay - cheap there. I don't know if i'd call it daylight but i would say especially in the rear area there are several times more light than stock bulbs and its a more natural slight bluish rather than yellow color. Luck!
Really depends on what you mean. You can replace the rear cargo light bulb with a brighter LED bulb and that will help. You can also add lights to your hatch that you can turn on when the hatch is open for more light.
I installed some Eagle Eye 3w LED lights to my rear hatch, and they're very bright. Here's the link for that. You can also use Super Bright LED to get new bulbs in your existing cargo light. If you're interested in the Eagle Eyes and want to know more. PM me and I can give you the details.
I'm thinking the panel (along with adapter) would sit inside the dome light, otherwise it sure would look goofy on the outside of the light cover! jmo...
I put 2 12" LED strips on each side of the cargo area above the rear windows and wired them to the original wiring. There's no bulb in the original cargo light fixture now but the 2 strips provide more than enough light. I picked them up for like $4 on eBay.
Here are a couple pictures of those led strips lit up. Way brighter than the one dome light.
IMG_0670.jpg~original
IMG_0671.jpg~original
large-square-universal-48-led-circuit-board-194-921-57-1156-3175-211.html
I used the 2 large square LED in my Map lights in the front and they are stupid bright the only problem I ran into was modifying the area to make them fit correctly which required me cutting a small amount of plastic out and bending some metal back to make room for 2 LED squares. I have led in my domes but I use some cheap bulbs from Amazon that were blue in color they were ok but the VLED seems like they are pretty well made
http://www.vleds.com/review/product/list/id/2303/category/685/
LARGE SQUARE UNIVERSAL 48 LED CIRCUIT BOARD 194 921 57 1156 3175 211 - 211 42MM LED - Shop Bulb #
Why are these vleds so expensive? You can get the same stuff on ebay for 2-3 bucks all day long!
I replaced the drivers side map light with a 12 red led square (helps keep night vision at night) and the passenger side map, dome, and cargo with 12 led white squares (BRIGHT!). Pretty sure it was less than $40 for it all off ebay. Still working great 2 years later. Liked them enough to start replacing back lights on the HVAC with white LED's.
Here is another thread about interior LEDs.
