Interstate MEGA-TRON 36r replacement?
xmytruck
Hello
Looking for advice Just got my oil and they tested my battery only producing 450 CCA. They replaced my original batter (2008 4 runner 110K) with interstate 36R they were able to secure the battery down and it does not move. I know that Toyota battery are usually 24F, should I be concerned ? They are both the same CCA 650.
thx
I think you'll be fine with the 36R. Most people upgrade with a larger battery, and as long as the cables reach and you can tie it down you will be fine. I would just check to make sure it is at least the same physical size as the stock battery as you don't want to go with a smaller one.
turbomikee
