iPhone 5 - Who's in?
Status
Not open for further replies.
The S3 uses a microUSB connector which is the industry standard for just about every other device. Apple PURPOSELY uses a proprietary connector to squeeze every nickel out of you.
Koz
Again, i wish that you would do more research....
"The problem with USB, though, is that it was designed as a protocol to standardize PC peripherals: keyboards, mice, digital cameras, printers, disk drives, that sort of thing. In other words, USB expects that you’ll be using a traditional desktop computer to load drivers to access an accessory.
The problem with USB is that it expects you’ll be using a traditional desktop computer at one end.
And that’s the problem. Your iPhone, your iPad, your iPod… sure, these are all computers, but they don’t load drivers. In conventional desktop computing terms, these are still accessories. So how do you get one accessory to talk to another accessory without drivers?
That’s where Apple’s 30-Pin Dock Connector comes in. It allows an iPhone, an iPad or an iPod to talk directly to compatible accessories, no drivers required. It’s the soul of Apple’s billion-dollar iPod, iPhone and iPad accessory empire.
The 30-Pin Dock Connector is what allowed Apple to turn the iPod, then the iPhone and iPad, into the hub of so many people’s digital lives. Thanks to the Apple Dock Connector, we have cars that can speak with our iPhones or iPads, televisions that can suck movies from our iPods and display them 50-inches high, and an endless and affordable array of iPod-compatible toys, peripherals, accessories and speaker docks.
It’s telling that the one iDevice that doesn’t ship with a 30 Pin Dock Connector — the iPod shuffle — is the one that has a negligible number of third-party accessories made for it: the iPod shuffle is the only iPod that uses straight USB instead of 30 pins.
We’ve already seen that a USB connector only has four pins: two for data, one for power and one for ground. It’s up to a connected computer to be able to load drivers to be smart and powerful enough to translate the data coming from a USB device into a format it can actually work with.
The 30-Pin Apple Dock Connector works quite differently, though. Each pin has a specific function, and all a compatible accessory needs to do is watch what data is coming through the specific pins it needs to provide that device’s functionality.
Think of the Apple Dock Connector like a lock, and a compatible accessory like a key. In any lock, there are a number of tumblers; for a key to open that lock, it needs to be precisely cut so that its ridges trip those tumblers and then unlock, say, a door or a box.
That’s how the 30-Pin Apple Dock Connector works. While two of those thirty pins do provide USB data-in and data-out for the purposes of syncing, the rest have very specific functions. The result is that if you plug your iPhone into, say, a speaker dock, the speaker dock’s connector is configured so that it only trips the pins it needs: in this case, audio out and power in. An accessory made to display video from your iPod classic on your TV, on the other hand, will be configured to only watch the video out and audio out pins. And so on.
The original 30-Pin Dock Connector was a remarkably future-proof design, and Apple has added functionality to many of the blank pins over time; until now, there’s a pin for nearly every function an accessory could possibly want to provide. The benefits for accessory makers are huge, because they don’t have to make devices with power-hungry CPUs to try to figure out and translate all of the data coming in and out of an iDevice into a format it can actually use.
But there’s a catch. While the Apple Dock Connector has lasted almost a decade without a significant design change, it’s one of the bulkiest components of an iPhone or iPad. That makes the Dock Connector a big bottleneck when it comes to slimming down future iPhones and iPads and giving them better battery life. After nine years, it’s in Apple’s vested interest to make a smaller, better Dock Connector.
In 2012, many of the pins on the 30-Pin Apple Dock Connector are reserved for obsolete technology.
A full eight pins on the 30 Pin Dock Connector are dedicated to maintaining Firewire compatibility. The only problem is that Apple has abandoned Firewire in favor of USB 2, Thunderbolt and now USB 3. It’s pretty much a dead technology. All of those pins can be reclaimed without impacting consumers or accessory makers (except in extremely marginal cases).
That’s not all. We’ve also highlighted pins 8, 9 and 10, which seem to exist only to provide pretty marginal video-out functionality to a handful of iPods. Between both the Firewire pins and the legacy video-out pins, we can easily shave 11 pins off of a 30-Pin Apple Dock Connector, leaving just 19 pins total.
That’s why the best option available to Apple is to just drop the pins accessory makers aren’t using from the existing Apple Dock Connector. Doing so will allow Apple to make the connector at least 37% smaller while still maintaining backwards compatibility by selling a 30-Pin-to-19-Pin adapter, which, of course, will also make Apple a tidy profit. All the while keeping relationships intact with both accessory partners and customers who might otherwise have seen thousands of dollars worth of their “Made for iPod”, “Made for iPad” or “Made for iPhone” accessories become obsolete overnight."
Read more at The Future Of Apple’s Dock Connector [Feature] | Cult of Mac
Just like no memory card (if you need more memory with an iphone it will cost you HUNDREDS more!) and no replaceable battery. I sometimes need more power then one battery can provide (when traveling) and for several dollars I have all the extra power I need!
Koz
You need extra battery because your phones sucks the juice out too damn quickly due to inefficient software (inability to properly close an app; inability to shut down FLASH, etc.) and inefficient battery management with hardware. In addition, your screen is huge which sucks juice...and despite the claims, SAMOLED sucks battery no less (if not more) than any other screen technologies. And if i have to travel, then anyone can buy those backup miniature battery pack for a few bucks too. No biggie. Lithium ion batteries rock. Replaceable battery also requires cheapa$$ plastic backcover instead of a solid piece of aluminum as in iPhone 5. Lets face it, NONE of Samsung products reek quality. Flimsy cheap plastic that would make Toys-R-Us blush with embarrassment!
Ok...tell me why Google themselves are moving away from memory card?
As always, I will help you find FACTS not bogus propaganda: (linky: Why Nexus devices have no SD card | Android Central)
"Google still supports removable storage in Android, but it is leading by example and providing phones (and now a tablet) with one big block of storage that users can use for anything they like -- be it media, documents, or apps. (REMIND YOU OF SOMEONE? APPLE MAYBE?) There are a couple of side benefits to this approach as well. The first one is a bit geeky -- it allows the device to use ext file systems instead of a mix of ext and FAT. This is faster and safer -- both for the data on the device and the way it's handled, and access to our own personal data. A journalized file system means fewer file errors, and ext preserves file system permissions so random code can't find your pictures or documents folder. (MAYBE APPLE IS NOT SO CRAZY AFTERALL?!!)
Another benefit is that the host machine (when your device is connected to a computer) can't muck things up and molest the file system, as it doesn't have block-level access to the files. Instead, a proxy FUSE (Filesystem in Userspace) file system is used to mount a psuedo-SD card folder so that your computer can read and write to it via MTP. This means you won't get errors from incorrectly unmounting your phone, and the device still has access to all the data even while plugged into a PC."
BTW, Koz, how much is your phone worth now on the used market? As of today, my iPhone 4S 32 GB is worth $395 at Amazon if i sell it to them...USED. How about yours? Care to post it?
:snacker:
Can we all agree that they all "almost" do the same thing at the end of the day?!
And everybody's needs are different, so we have a choice of phones to choose from. Choice is the best thing to have.
:snacker:
I agree. However, there is a distinction b/w what are FACTS and what are just bogus misinformation by fanboys.
:snacker:
You hit the nail on the head. This will be an argument that will never be won as each of us values each individual feature differently. As someone who currently uses a windows home server, boxee box, android phone, ipad2, apple tv, roku, and a MacBook pro on a daily basis I understand that what works for me may not be the best setup for someone else.
People need to stop banking everything on specs and headlines and go into a store and try a couple phones. Their decision should be based on what the best phone is for their individual needs.
Over saturation is one of flavors of cool-aid Apple was serving. It’s funny how Apple increased the amount saturation in the new i5 display. Retina display is another flavor; it is just a fancy name Apple’s version of their HD display (all the top phones have almost the SAME resolution. By the way there is a HUGE difference between LCD (old tech) and AMOLED and again Apple is a dollar short and a day late. Just like Corning Gorilla glass vs broken screen!
As far as speed, on paper yes the A6 makes the i5 to look faster but only time will tell. The S3 has proven to be the fastest phone to date. Its dual core 1.5s and 2 GB of ram run as fast as a quad core. Notice how Apple only compares the i5’s speed to the i4S. It’s amazing how the A6 i5 is already the class leader when there has not been one comparative test done yet (some people need to put the cool-aid down) Again, time will tell!
As far as battery life, 8hrs - 1450 mAh vs 11 hrs – 2100 mAh lets see, that looks like 37% better to me. These are OEM specs without cool-aid.
Lets see, I buy a i5 with 16GB ($200 more for 64GB) of embedded memory and I need more memory; what I need to buy a new phone! OR I buy a S3 with 16 GB of removable memory and SIMPLY buy a 64 GB microSD card for less then $100.
Koz
You have got to be kidding! Apple = nickel & dime you!
Sounds like you drank a gallon of that cool-aid!
Koz
Koz, iPhones have had Gorilla glass for a long time...long before Samsung! :D Steve Jobs is what convinces Corning to use the glass on smartphones.
As for saturation, do ANY google search on legit smartphone screen comparo...all of them said the same thing...Sammy goes overboard to get high contrast by oversaturation of colors (all part of SAMOLED). Go ahead...do a search!
Memory...memory card is falling out of favor for OBVIOUS reasons. Your choice. It is like FLASH...it is an outdated technology that sucks. PLEASE READ ABOVE FROM Android website!!
Again, READ UP on A15 Cortex CPU...it is better, simply said. A15 is Samsung pride and joy...it is just that they could not get it ready for GS3. DO YOUR RESEARCH!
Koz
instead of fanboyism, why don't you provide some facts to disprove what you read. I dare you. Open your mind dude. Did you even read it?? You need to use some brain powers dude.
Did you notice that your laptop/computer searching for drivers when you insert your phone via micro-USB?? Hint: read above!
Got to say, you will believe ANYTHING that will justify your cool-aid induced ideas!
There is only ONE reason why Google devices don't have memory cards. They want you to use their online memory, period!
Who in their right mind would want to be limited to embedded memory, lol -YOU!
As far as used valve of the S3, it only costs $140!
BTW - I have NEVER had a problem with any memory card or lost any data, EVER!
Koz
Koz
Read this again: What do we know about Apple’s new A6 processor? | Ars Technica
It is kind weird that Apple iPhone 4S with 500 MB RAM and only 800 MHz was able to hang (and beat) Android phones with 1GB RAM and 1.x GHz. Weird indeed. In other words, Koz, the specs you listed are meaningless.
Despite all those specs, your browser still lags; your homescreen switching still twitches.
When are you going to get Jellybean? October? Get ready, that will be your last major software update till death of your phone. Remember, unless you are a Nexus phone (and that is still not 100% true; trust me!), your lifespan is 18 months or less on all Android phones...as confirmed by Google. Basically, your phone will be worthless in LESS than 2 years! Think about that for a moment....
did you actually read any of the info that Thai posted? you just keep saying the same thing over and over again without any proof, not even an article or anything. the S3 costs a lot more than 140 also, do some research. I would rather pay for a quality product that will last me. when I used android, I had to replace my phone every year because the old one started crashing, mainly because it would update, and the phone couldn't handle the new version of software. my wife's Iphone has lasted for the past 3 years and hasn't had a single problem. works just like when it was new. my Macbook is almost 5 years old now, and works great. it is faster than my friends brand new windows laptop. I prefer to pay more for a better quality product. you can throw specs at me all day, but in the end, the quality doesn't compare. it's like comparing Toyota to Ford, sure ford has some faster cars, and maybe trucks that can haul more, but Toyota is still better.
Koz
I did NOT write that article. Nor did any Apple fanboy write it. IT'S ANDROID FANBOYS who wrote it! Get it?
Oh dear, are you THAT blind that you don't even see it? Koz, come on! Dude, that was YOUR OWN FOLKS (Android Central) talking about it! They even dispel your conspiracy theory!!!!! This was reported on CNET, Engadget, etc.. This is widely known. I am shock that you are only realizing it now.
Here is the conclusion of that Android Central link: "But there is no secret evil cabal in Mountain View that held back the SD card slot to force it on you. In fact, you're still free to use other cloud solutions like Amazon, Dropbox, or even a shared drive on your desktop PC. Nobody has to like the fact that Nexus devices ship with no SD card slot, but let's stop looking for conspiracies when we already know the answer."
Drop the fanboyism which you are well-known for...and open your eyes! Facts are right in front of you!
Koz
That's because it is loses value about a month after it is release! And when you do sell it, it is worth a few pennies.
My iPhone 4S 32Gb was $300 new (contract price)...now, i can sell it to Amazon for $395. PROFIT. Of course, i can eBay it for a lot more too. But, i like to use Amazon because that is a good basis for comparison.
Soon there will be head to head testing on the S3 and i5. Time will tell!
I just bought the S3 at Wally World for $140 something.
Koz
Koz
If you had the international GS3, then you have a chance...but with the Snapdragon S4, it will be an uphill battle against A6 and Apple's GPU. The A6 is simply better than anything this side of the pond.
You got it for cheap because that is what it is worth under contract. Android phones lose value instantly. And with a lifespan of less than 18 months in terms of software update, you are left with a brick and yesterday's software. And you won't be able to sell it.
My Galaxy Nexus S 4G is worth $66 bucks at Sprint after less than 2 years on the market.
I understand your enthusiasm for something you just bought...but there is no reason to be blinded by FACTS. None of what you wrote makes sense nor is backed by any known facts.
Having used many different droids and also having used the iPhone, and as well as being in the industry.....I can tell you there are less issues with apple products and a simplicity with the iPhone that is very hard to beat. That's what sells it. Plus people think its like this status thing or something. Some people want to get one without even knowing why. Excellent marketing.
However, droid has its place for a lot of people. Much more customization and until the iPhone 5, much faster speeds (4G).
I agree with what's being said, at the end of the day it's just a phone and people will always be on one side of the fence or the other.
Status
DJNutshell
