Is it possible to add a....
ACarter
I have a 2016 Sr5 and i wanted to know if it's possible to had a diff locker if it didn't come from the factory with one?
nope. you are going to have to sell it to get one that has it from the factory.
next time search harder. ARB makes air lockers for the front and rear diffs.......
You have a few options.
TJM air locker
ARB air locker.
Harrop/Eaton E-locker.
And OEM Toyota e-locker. This one is not just bolt in the locker, but you could either modify your housing or buy a replacement housing and install an OEM e-locker plus wiring. A used E-locker axle assembly complete from hub to hub - so you'd bolt this directly into your suspension parts, then deal with wiring, is around $1500. If you can get $500 out of your old axle - this might be a reasonably comparable cost option to the other alternatives. All new parts would probably run you more like $3k+.
Try ATRAC first and see if you think you really need a rear locker.
Yeah i saw that they make them but i thought it was more of replace what you have rather than add on.
I'm currently reading this post
All aftermarket locker options will require replacing the carrier assembly in the differential. I don't think there are any lunchbox lockers out for the Toyota 8.2, and I wouldn't hold my breath for one. Atrac works really well. Most people wouldn't deal with the harshness of a lunchbox locker on a daily basis for the moderate gain over Atrac. If it was free - I wouldn't put a cheap locker in. I would only upgrade to a selectable locker. On my trail rig - I prefer auto lockers in the rear by far. But on my daily driver I wouldn't want one.
